Mon, Jan 27, 7:39 AM CST
Subject: War in the heavens pt2
Rickm ( ) posted Tue, 11 April 2000 at 8:26 PM ยท edited Sun, 26 January 2025 at 4:32 PM
Content Advisory! This message contains nudity, violence
Second in this series, actually have a few diff renders of this shot with different atmospheres if u care to take a look http://home.earthlink.net/~rickmhsd3/poser/angel2.jpg thru angel4.jpg Criticism welcome, alhtough I doubt I will revisit this it will definatley help on the next one. looking for chain and shackles if anyone has a posable set ) rendered in bryce file size 80 megs I suppose I should also credit the props, wings are obvioulsy hokusiwings and the sword is the runeless sword (no details)by emjaysea
Rickm ( ) posted Tue, 11 April 2000 at 8:34 PM
I guess I should explain the not revisitng it part, I was using open GL in bryce and evertime it crashed it corrupted the file, so I would have to use a previously saved (under different file name) and start over. Using direct 3d seemed to have fixed this, crashes were less frequent and it hasnt corrupted the file yet. However the saved state I have it in now has a totally different atmosphere then any of the pictures.
Roshigoth ( ) posted Tue, 11 April 2000 at 8:35 PM
Umm.. you could really use some textures to bring this stuff out.. Everything looks blank... Also may want to make sure that Bryce's gamma correction is off. That usually helps, especially when working with Poser figures, as things look washed out when it's on. You might want some sort of scenery, even if it's just some volumetric clouds.. Once again, the scene just feels really blank. But maybe you wanted it that way. If so, nevermind. =) As for the bryce size, it's probably due to all the poser figs.. they'll do that. Rosh
LoboUK ( ) posted Wed, 12 April 2000 at 4:38 AM
This could definately use some texture-work and scenery. IMHO it's just too bleak. That being said, the actual composition of the image is excellent. Paul
