Tue, Feb 18, 7:48 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Poser Performance
cpharrboy ( ) posted Tue, 19 November 2002 at 12:44 PM · edited Mon, 17 February 2025 at 8:57 PM
Does anyone know of any tricks or tweaks to improve the performance of Poser? I upgraded to WinXP pro hoping that would help but it only helped slightly. I guess that was due to WinXPs better memory management........
PabloS ( ) posted Tue, 19 November 2002 at 12:46 PM
addtional memory is typically the best performance enhancer. How much do you currently have?
cpharrboy ( ) posted Tue, 19 November 2002 at 12:48 PM
I have 512mb of pc2100 DDR set at CAS2
kuroyume0161 ( ) posted Tue, 19 November 2002 at 1:10 PM
That's not bad, cpharrboy, but another 256 or 512MB wouldn't hurt. What's your processor and its speed?
 -- Bjarne Stroustrup
PabloS ( ) posted Tue, 19 November 2002 at 3:04 PM
I've got 512 DDR with AMD 1700+ and all seems well on XP Pro. Make sure you don't have a lot of stuff running in the background. Although that's probably obvious, someone asked a similar question about a month ago and provided a screen shot. They had about 10 applications running in the background. You might also try setting your virtual memory to 1.5 times your RAM.
Taylor4 ( ) posted Thu, 21 November 2002 at 10:57 AM
If its not running well on YOUR system I'm surprised. If you have an Nvidia graphics card you can change the Direct 3D Mipmap detail level to "High Performance" rather then "Best image quality". That should give you an increase in your ability to scroll around on the screen, without much difference in image quality. If you go one step further to "Best performace" you'll notice a drop in preview image quality, but your full renders should look the same. All Nvidia cards have this option under Control Panel--->Display---->Advanced---->Name of video Card---->Additional propertys----->Direct 3d Settings... Whew!
