Same here. Any problems with my images are purely "Operator Error". The software works fine. You will have to get the menu bar to appear and minimize before you can use multitasking however. You can't go to the start bar and click from bryce to poser. Bryce always dominates. Maybe it's this way in the other OS's as well.
I'm running XP Home Edition and I haven't had a problem. Well, at least, no problem that the app doesn't have in any OS, such as locking up in Tree Lab if you push the numbers too high (which it did to me last night). I think moving to XP is a wise move, especially if you are running ME (which sucks IMHO). XP is definitely the most stable, user friendly OS Microsft has made.
I'm running B5 on XP home edition. I have only 2 complaints about it. It has a tendancy to crash when running Windows Media Player while working, and you cannot flip between software by the taskbar on the bottom, you have to minimize Bryce first before flipping between windows. Other than that, it's stable as a rock and fast too.
I have only found one problem running on XP, my laptop will sometimes have display errors when running Bryce and an IM indicator will pop up, either from AIM or MSN. And the problem will also only occur if I keep the taskbar set to auto-hide. Otherwise, it's fine. And I don't even see that as a Bryce issue, but rather an issue with my laptop. Oh, I'm using XP Pro, by the way. I also found out the hard way that running Bryce on a Win2K Advanced Server can also be......bad...
Same as electroglyph on my dual boot ME/2k system in both OS's. However, all I have to do is move the mouse to the top and minimize, or quickly move back to the hidden lower tray. Oddly enough, ICQ or mIRC used to raise the lower tray when they went off and a few months ago that stopped. I don't know if it was loading a program that did this or not. Unfortunately, I haven't kept a log of when I load or change things in relation to oddities that occur.
I'm about to buy it, and I can't find a straight answer on the Corel website. I imagine you guys will know.
