Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
First click on the sun/moon sphere at the top of the screen then try crtl + alt in the working window. Otherwise if you have your camera facing with a Y rotation of 0 degrees then if the sun is at the top in the sun/moon sphere the sun should be directly in front of the camera. Go into the sky lab, change the preview window to "render in scene" and lower the sun until it is around 5 degrees altitude (azimuth 000). You should see the sun, then just place where you want it using altitude and azimuth.
You also have to sometimes be very close to the horizon to see either. I can never use the little sun controls track ball. I always overshoot. Look at the little Azimuth: and Altitude: settings. If you click on the numbers next to them you can manually change the values to move the sun. Azimuth is around the disk 360 degrees. Altitude is from edge to center 90 degrees. Sometimes you need to be 15 to 20 degrees just to see the sun disk. Click on the little yellow ball to the right of the trackball and it will change from yellow sun to blue moon and change your scene from day to night. Sun and moon are always 180 degrees apart in bryce. If you want both in the sky at once you will need a to put a moon texture on a sphere and hang it in your scene. Hope this helps!
Thank you all very much for your help. Somehow today I finally got the ctrl+alt to work and place a sun!! I have no idea why it wouldn't work last before, but all seems well now (cross your fingers for me that it keeps on working! ;-) I did also play with the azimuth and altitude settings and understand them a bit better, so this has all in all been a good lesson for me! Thanks again!
Sometimes, they can be obscured by clouds, you can fix that by decreasing the clouds.
Am I just stupid or what? I just got Bryce 5 and for the life of me I can't get either the sun nor the moon to show up in the sky. I've tried everything I can think of short of cutting and pasting a dang picture of the moon there! Can anyone help????
