Thu, Nov 14, 5:13 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Need help understanding object distortion during rendering
Zenman53186 ( ) posted Mon, 25 November 2002 at 1:42 PM · edited Thu, 14 November 2024 at 4:56 PM
Attached Link: http://home.wi.rr.com/zenmanorg/GemUnrendered.jpg
I've been playing around with reflectivity on gem models and running into a strange problem. Certain vertices of the model are displaced from the normal locations. No displacement mapping was used, and displayment mapping was turned off in the renderer. I also turned of the "smooth edges" feature for the object.
Note that it's intersection the floor just to give a better illustration of the issue.
Here is the image without rendering with "smooth lined" selected.
Zenman53186 ( ) posted Mon, 25 November 2002 at 1:45 PM
Attached Link: http://home.wi.rr.com/zenmanorg/GemRendered.jpg
... and here it is rendered. Note the distortion outlined by the floor surface.
SAMS3D ( ) posted Mon, 25 November 2002 at 2:21 PM
You might want to put it in UV mapper and split the verticies....Sharen
thgeisel ( ) posted Mon, 25 November 2002 at 2:33 PM
yes, sharen is right, use uvmapper.Only way that really helps. Other thing: uncheck the smoothbutton in the obj properties ( works only with the lastes patch) or in the renderoptions
thgeisel ( ) posted Mon, 25 November 2002 at 2:34 PM
but save your time,also in p5 you will not get a good looking gemstone.several people (including me ) tried without any usefull results.
JeffH ( ) posted Mon, 25 November 2002 at 3:21 PM
Turning smoothing off in the renderer and object properties does not help?(P5)
bloodsong ( ) posted Mon, 25 November 2002 at 3:32 PM
heyas; he said he turned the smoothing off. what happens when you render it without transparency? oh... check for polygons with more than 4 sides. those do flaky things, too. are you using the p4 renderer or the firefly? does it come out differently either way?
Zenman53186 ( ) posted Mon, 25 November 2002 at 7:35 PM
Attached Link: http://home.wi.rr.com/zenmanorg/GemRenderedP4Renderer.jpg
Okay, tried rendering with the P4 renderer. Quite a difference.
I'll look at it in UVMapper, but don't understand what that would do to it. Not sure how to "split vertices".
BTW: The gem is from the DAZ3D "DragonHoard" collection; I'm guessing a DAZ modeler built it.
redon634 ( ) posted Mon, 25 November 2002 at 8:57 PM
Zenman53186 - not sure if you saw my post over at PoserPros, but I've had luck with the gem models over at 3dlapidary.com - you can download them in a variety of formats, and I haven't seen any smoothing or model problems in P5 with the ones I've used. I did have trouble with the cabachon model causing a c-exception in P5 in the .3ds format (which I reported to CL and they were able to replicate - that was at beta3, it may be fixed now) but haven't had any errors on the others I've tried. If you just need some working gem models for P5, you can try there.
Zenman53186 ( ) posted Mon, 25 November 2002 at 9:47 PM
Major thanks, redon; I'll try going there.
Zenman53186 ( ) posted Mon, 25 November 2002 at 9:49 PM
Oh, wow, they have some beautiful gems, don't they? Man oh man, candy shop time... I hope they render as nice as they look...
bloodsong ( ) posted Tue, 26 November 2002 at 2:20 PM
hmmm. is that what it's supposed to look like, that new render? looks like some kinda ray-trace deal then. might want to report it over at the sr2 beta forum.
