Sat, Jan 11, 7:07 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: Lots of Shaders! released
litst ( ) posted Tue, 26 November 2002 at 1:33 PM · edited Sat, 11 January 2025 at 7:03 AM
Attached Link: http://www.chez.com/litst/LoS/products_LoS.htm
Hello, I've released Lots of Shaders!, a collection of pre-made shaders for Carrara Studio 2.1 . The pack contains 120 procedural shaders covering a wide range of materials . It's available for $40 on Renderosity.com . See the product page on my website where you can download a free sample pack : http://www.chez.com/litst/LoS/products_LoS.htm I hope you'll like the shaders ! Best regards, litst litst@chez.com -----> http://www.chez.com/litst
bluetone ( ) posted Tue, 26 November 2002 at 1:51 PM
How come there isn't a cheddar shader? ;>
litst ( ) posted Tue, 26 November 2002 at 1:57 PM
There is ... middle of second line ... it looks like plastic ;)
Kixum ( ) posted Tue, 26 November 2002 at 2:20 PM
-Kix
Pinklet ( ) posted Tue, 26 November 2002 at 2:33 PM
Litst:
In theory, this pack would even provide a bigger value aside from getting all these wonderful shaders, if it actually shows you how you put them together. In other words, this package provides you with a recipe for all these shaders?
They look great.
litst ( ) posted Tue, 26 November 2002 at 2:48 PM
No real recipe, though there are tips on how to use the shaders in the pack, and shaders in general . If you're interrested by these tips, you can have a look at the readme, it's available on the product page . I've tried to put a little something unusual in most shaders so people can discover new techniques as they dissect them . Also, some shaders are not meant to be used as is, but instead to show specific techniques (weight maps, complex noises, wire netting ...) litst
Pinklet ( ) posted Tue, 26 November 2002 at 3:14 PM
I will check out the readme file. It looks like a good deal. Thanks.
memaci ( ) posted Tue, 26 November 2002 at 9:00 PM
I learned so much from Real World Metals, this new shader pack is hard to pass up. Will they work with C1.1? memaci
willf ( ) posted Tue, 26 November 2002 at 11:27 PM
Thanks litst, these are really neat. Hope you don't mind a little "extra" info for a few MacHeads-
To change the PC shader to a MAC shader (for Mac users):
Drag the shader file onto ResEdit then "Get Info" for the file
& click OK when the pop-up window asks if you want to add a resource fork. Then change the "creator" type to CRRA and change the File type to CBRF. Save the change & you're in business. Or, copy this AppelScript into a new script (launch Script Editor & just paste it in). Save it as a script application. Then just drag your shaders onto the script, no muss, no fuss. The script will change "any" text file so be careful with read-me files, etc.
on open the_files
repeat with a_file in the_files
set item_info to info for a_file
if not folder of item_info then
tell application "Finder"
set the creator type of a_file to "CRRA"
set the file type of a_file to "CBRF"
end tell
end if
end repeat
end open
litst ( ) posted Wed, 27 November 2002 at 12:09 AM
Memaci, Most of the shaders will work perfectly with CS 1.1, but there may be some little differences with some of them . Here's the part of the readme that talks about this : --------------------- > IMPORTANT ! > Lots of Shaders! is designed for Carrara Studio 2.1 . If you use a previous version (Carrara 1.0, Carrara Studio 1.1 or Carrara Studio 2.0), there may be some compatibility problems that, in the worst cases, might cause Carrara to freeze with some shaders that have a complex structure (such as the eye shader) . Those problems should be very rare, though, and you should still be able to use the majority of the shaders . --------------------- You'll see Carrara freeze if you open the eye shader in CS 2.0 (no problem with CS 1.1 though), and some complex structures in other shaders might cause problems too . Will, Thanks for giving us this tip . The pack has been tested on CS 2.1 on Mac and the shaders opened okay because the problem you're refering to has been fixed by Eovia in 2.1 patch . I'm not sure, you may have to convert the shaders the way you described if you're on a previous version of Carrara ... but maybe not, it depends if the bug has been fixed on the PC side or on the Mac side . litst
Pinklet ( ) posted Wed, 27 November 2002 at 9:25 AM
I did download the sampler and they look great. I got to gather my funds, but I will be getting this in the future. Good work litst.
Willf, I just downloaded the zip file it expanded with stufit expander and I just used the browser tray to include the new folder, of course, I am using OS X 10.2 which doesn't really need the resource forks if the files have extensions.
willf ( ) posted Wed, 27 November 2002 at 9:47 AM
Thanks for the info Re OSX, guess I'll need to upgrade one of these days. The above info is apparently only for Mac OS 9. The shaders do seem to work with C 1.1, although I didn't play with them too much. Suppose I should upgrade to C 2 one of these days also!
pixelmouse ( ) posted Tue, 10 December 2002 at 3:43 PM
FWIW Bought both LOS and the Real World Metal Shaders last week and they are both fantastic. Pete UK
litst ( ) posted Tue, 10 December 2002 at 4:00 PM
Thanks Pete, glad you like the shaders :) I'm receiving a very, very good feedback on those . More to come ???
twillis ( ) posted Sun, 15 December 2002 at 10:37 PM
Whoa! I'm a bit behind the times! Just now getting caught up with email and the forum. You guys have been busy! Terri's Cheddar, huh? Compliment, or not? Cracked me up, dude. Too funny. I'm looking forward to shader experimentations, now that I'll be home for awhile.
