Tue, Sep 24, 5:20 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 24 12:07 am)
Subject: P5 - Creating a single figure with mulitple props
drgonzo ( ) posted Thu, 28 November 2002 at 4:48 PM ยท edited Tue, 24 September 2024 at 5:17 AM
I am trying to create a single figure with mulitple imported props. So far as i understand the manual it should be possible, but i see no way to select several props to create a figure with a global bonestructre in the setup room. I tried a few workarounds, but they just crashed P5.
Does anybody has a solution ?
Little_Dragon ( ) posted Thu, 28 November 2002 at 7:38 PM
Load or import the props in the Pose Room. Export them as a single .obj mesh. Import this mesh into Poser, and take it into the Setup Room.
drgonzo ( ) posted Thu, 28 November 2002 at 9:25 PM
I already took my .obj files and imported them into P5. Now i want to use those props (all of them at the same time) for one figure with one global bonestructure... one prop is no prob ;-) but more than one gives me headaches thx anyway :-)
stewer ( ) posted Fri, 29 November 2002 at 5:56 AM
Use hierarchy editor to create a simple hierarchy of your props, then select "create new figure". It'll save a new figure to your library which you then can take to the setup room for further tweaking.
