Sun, Jan 26, 12:18 AM CST
Forum Moderators: Staff
Subject: Parented Spotlights screwing up joints
_dodger ( ) posted Fri, 29 November 2002 at 6:30 PM · edited Fri, 24 January 2025 at 4:57 PM
I've recently run across a really odd phenomenon... I tried to parent two spotlights to the flame on a torch. Every time I do this, the spotlights somehow end up messing up the joints. The endpoint gets really weird. The bend translator works in reverse. Things get very strange. This was really confusing me for a while because I thought it had something to do with my Gravity Well. But I removed that (and loaded it up anew) and the same problem persists. So I tried using a 'clean' figure -- the one created in New Figures -- and was going to save it and start from scratch -- when to my surprise the prroblems I'd been having tranasferred to that as soon as I added the spotlights to it. Is this a known issue?
_dodger ( ) posted Fri, 29 November 2002 at 8:11 PM
Well, anyway I came up with a workaround. I have a cube set in the centre of the flame and parented by it and this cube is parenting the two spotlights. It seems to work pretty well now.
lesbentley ( ) posted Fri, 29 November 2002 at 8:59 PM
Stay off that bad acid man!
lesbentley ( ) posted Fri, 29 November 2002 at 9:04 PM
Seriously, this spotlight problem sounds really weird, but the torch is looking great. Glad you seem to have solved your problems. I must check out this strange phenomenon.
lesbentley ( ) posted Fri, 29 November 2002 at 9:31 PM
I tried parenting spotlights to Posette's shoulder and hand, everything worked as expected. From what little I know of Poser I would not have expected a child to affect its parent in any way, unless there was a weld involved. Is this happening immediately you parent the lights, or only after a save to the pallet?
_dodger ( ) posted Fri, 29 November 2002 at 11:12 PM
It was immediately. Like I said, it was really really weird. I don't know if it may have been related to the fact that I had 2 parented by it. But the in-between prop fixed the problem anyway. B^)
