Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 27 2:29 pm)
By the way -- these are being made with much, much more attention to detail and trick-effects than my free torches. Not that the free torches are anything to shake a flaming stick at. For instance: - The flames are affected by gravity using a special technique that lesbentley and I worked out. - The lights will come parented by the props. - The props will all be fully UV-mapped. Most will be textured and bumped (look at that filigree!) - Most props are/will be posable and animatable (including all of the fire props). - Most props will be morphable for custom designs (see, for instance, the foreground and background images of the ornate torch, above). All the flames are morphable. - The base flame object has been modified to make it render well from above, too!
OOOOOOOOOOooooooooooooh now THIS looks good!! Wow I would like to own those. drooool
