Thu, Nov 28, 11:11 PM CST
Subject: How to edit Poser 5 *.crz files manually?
Sentenza ( ) posted Sun, 01 December 2002 at 8:25 AM ยท edited Mon, 25 November 2024 at 10:28 AM
Is there a way or a tool to edit the *.crz files outside of Poser 5? Like a new "Morphmanager" or "cr2 Edit"?
MartinC ( ) posted Sun, 01 December 2002 at 8:28 AM
.crz is simply a variation of .zip/.gz compression, so you can expand the files with a suitable un-zipper (WinZIP etc. on PC, StuffIt Expander etc. on Mac) and get the normal "text" file version.
Sentenza ( ) posted Sun, 01 December 2002 at 8:42 AM
It works! I renamed the result to *.cr2 and there we go... ...just found out it can also be done by just resaving the figure with "compressing files" disabled, we get the regular *.cr2 file. Thanks for you hint!
Puntomaus ( ) posted Sun, 01 December 2002 at 11:48 AM
There is a Python script included with P5 that decompresses all your files in the libraries. In the Poser5 Menue it's under Window - Python Scripts. In the Python window click on Utility Funcs and then on UnCompress Files. To compress all files again simply click on Compress Files.
EricofSD ( ) posted Sun, 01 December 2002 at 10:21 PM
You should make a new figure instead of resaving. The poser patches won't update files modified outside of Poser. I went through this with a Judy morphmanager mod to get Mimmic working and found out the hard way, had to reinstall poser.
