Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 5:18 am)
Hi I had the same problem with a background I created in bryce. I may be wrong, and no doubt someone will correct me, but I think that even if you increase the resolution of an image you will not necessarily get an increase in quality, in short you cannot go beyond the quality of the original image. I think that there are image enhancing programs/plugins avalable which use some sort of fractal 'magic' but where off the top of my head I couln't tell you. hope this helps If not I'd sure like to here the 'real' answer Dave
I tried bringing in the background on a flat prop and that helped a little, but the best was to build it in Photoshop and use the alpha channel to transfer your Poser figures. I had more luck with unsaturated images like Surrender in my gallery-- that was rendered all in Poser. Everything else since has been brought into Photoshop. Emily
It appears that when importing a background, Poser will scale this image to the size of your current composition window (not your render size). It will then use this resampled image for both your working display in the composition window, as well as the render.
For example, create a grid 800x800 and import it as a background image while your composition window is at 800x800 and it renders OK. -- Import this same image while your composition window is at 300x300 and it gets all fubar in the render.
Same background image, different results depending on the current size of your working composition window.
It would therefore appear that you cannot get a background image to render at any resolution higher than that of your working window, regardless of the original background image size or final render size.
i think if you put the image on a background prop (one sided square) but first make the square huge like a 5 or 10 thousand percent larger, then scale everything else much bigger so that square appears normal size, i think it renders at the resolution closer to what the original picture was. try it im not sure just experimenting
Attached Link: http://www.lizardtech.com/
The Wanderer, are you referring to this fractal enhancement plugin?This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
not sure i do it right, every time when i render a image with back drop or backgound image, and render it as high res. like 3000x3000, the object or figure stay in high res. but background seems still very low res.(even I use high res. background)and i end up have to replace the background image again, and it is hard work because the image in render was bent. and the replace original image is flat . very difficult to match up. did i do it in a wrong way?
