Tue, Jan 14, 9:39 PM CST
Subject: HELP me before I pull all my hair out !!!!!
Infra5 ( ) posted Mon, 09 December 2002 at 2:22 PM ยท edited Tue, 14 January 2025 at 9:37 PM
Ok so I have been working on a pic that I have had to redo 5 times now resone being is I have all the tex in the pic for my poser person I inported on the person,Then I add the back ground the sky the trees wanted but when I go to save it it keeps saying that Bryce5 has caused a invalaed page fult in the Bryce exe kurnal ect... Why is it doing this?I tried to reinstal it I got the new update every thing but still it dose that and I keep loseing my pic I am working on!!I even tried rebooting but still it dose that when I have all the trees and back ground and tex on my poser person?Last night I got a new eorror it was it caused a ganertic eorror and it did this when I tried saving my poser person as and object in the creat part.I t did it when I tried to do that then when I tried to save the pic it's self I dot that now when I try to load the file it say I hve twp objects but it never fully loads them ?What is going on what is Bryce doing?
SAMS3D ( ) posted Mon, 09 December 2002 at 2:53 PM
A couple things might help, first do you have a backup file for this original pic? Second is Poser the application open at the same time Bryce is? Third do you have any background software running while you are trying to save your pic? Sharen PS: what OS are you running?
Infra5 ( ) posted Mon, 09 December 2002 at 2:58 PM
no I can't get a back up it crashes on me 2nd no other program is going at the time I use Bryce 3 win98 2nd adition 4th no only my fire wall and system and explorer in the back ground
SAMS3D ( ) posted Mon, 09 December 2002 at 5:06 PM
Okay, so do you have any of the file saved? Sharen
SAMS3D ( ) posted Mon, 09 December 2002 at 5:07 PM
maybe you could send it to me and I can look see if there is a problem....if it is that important to you...I really can't tell from here what the problem is. Sharen
Nukeboy ( ) posted Mon, 09 December 2002 at 8:30 PM
First, do you have the latest patch? Second, try running the object you're importing through Grouper 1.4+, it may need repairing.
ringbearer ( ) posted Mon, 09 December 2002 at 10:59 PM
Also try checking the names of the 2D textures you are using, if they are too long you can get an error. I would also save my scene in steps, that way you can always go back but don't have to start over. If it is a very large file, do it in pieces, then merge when you are ready to render. Good suggestion to run the object through Grouper. Good Luck! Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
bikermouse ( ) posted Tue, 10 December 2002 at 1:47 AM
Infra5, also, I believe W98 limits you to 128Meg of memory. there are memory managers designed for W98 to help with this - also save between steps with a new filename. Grouper is good to clean up the file but in bryce 3.1 the textures do not seem to be imported with the object, so I think you'll still have to do that part manually. - TJ
Rayraz ( ) posted Tue, 10 December 2002 at 6:33 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=971557
Lack of memory might be the problem. I've heard that bryce won't save if it doesn't get enough RAM. I've never experienced that problem myself, but here's a thread that might help: http://www.renderosity.com/messages.ez?Form.ShowMessage=971557
(_/)
Infra5 ( ) posted Tue, 10 December 2002 at 3:10 PM
thank you this I hope will help me out alot!!!
