Um, if you make the Body invisible, you can't get it back. I just discovered that the other day. :< No amount of checking/unchecking in the heirarchy thingy did me any good at all. Had to dump it and start over. Of course it may have been a fluke. I've had no problem with individual body parts though.
Whathaheck are you talking about? If P4, and switching the visibilitiy 'Eye' back on in the Hierarchy Menu did not work, try pulldown menu: /Figures/Show All -or- -Select GROUND -Arrow-up until you get to the body that's invisible -Select Properties for Body and switch visibility on there. Once you have the body visibility back on, you may still need to return to hierarchy menu and restore individual bodyparts there.
I had the same thing happen . I was making a scene and then taking it apart to render small bits at a time i could import as alph channels into photoshop. After hours spent trying to bring back missing parts i redid the scene then saved it as a pz3 file and just reloaded that after each render . Kind of a pain but not as much as trying to un invis things that seamed to have fallen into some wierd dimension .
Just to let you know, in P4 I've had a number of files (with numerous figures posed) become corrupted where a previously saved file is opened and the figures are listed in the drop down menu but are not on the screen. They were on the screen when I saved the file, but are now invisible. No amount of Show All, Hierarchy checking, arrowing up, or double clicking helped. I just had to start over. I could never predict, force, or track the problem. It was just an unwelcome surprise. My suggestion is never save over a previously saved file. Just save new versions. When your hard drive becomes full or slows down too much, judiciously delete older versions.
Okay, so silly me went and made some of the stuff in my scene invisible, and now I can't select it to make it visible again. A little help please? Thanks.
