Hi Dannii, The problem with "missing" files is that they will be asked for on every material that uses them. On Victoria there are twenty or so material zones, some head, some body. Net result you have to keep on clicking! What you did clicking the JPEG to replace the BUM is the right thing but you have to keep on doing it for every requested file, just read the .BUM filename it wants and click the equivalent JPEG, and repeat until it stops asking. Its repetitive but once youve done it once you can save over the original character and it won
t happen again. Failing this you need to open the JPEG in a paint package, save it out as a .BMP file and rename that as .BUM. JPEGs are compressed, BUMs aren`t hence your error messages after renaming it. Hope this solves it :) Mark
I have Poser 4.0 and ProPack with all the latest updates. I have purchased Victoria Orc. However, when I try and load the figure it keeps asking me to find the VicHeadBump.bum. I point it to the only available file VicHeadBump.jpg and it comes back asking for the same file. I have tried just renaming the .jpg to .bum but then it comes back with 'missing file'. Can you help? Many Thanks in advance.
