Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 4:58 am)
I asked this very same question to the wonderful creator of this mouse Anton and was told this : "You can't redistribute textures at all but if you did it by changing the material colors in Poser you could distribute a MAT file. Not sure if this helps. Thanks for checking. Anton " ( end quote ) I asked because i saw people doing the same thing with hair and adding the colored textures. So as long as its just the mat the answer is yes , if you colored the texture in a paint program and were going to add that the answer is no.
Thanks tasquah. Well, it has to be a nono then. Modifying the texture in Photoshop was the easy way for me because I have worked with that for years and I am still new to Poser. I divided the texture in 3 layers: fur skin and eyes, which allowed me to change them seperately. If I can get the same effect in Poser I will make the MAT file available.
Astride, as long as you modify a commercial texture for your own use it should be ok and you can post images of that. You just cannot re-distribute such items, in this case the original but recolored texture. That would be a violation of copyright because you use the work of someone else.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
