Lets see... Defragged a couple weeks ago.. fragged hard drives have never given me illegal operation messages.. Haven't done thorough scandisk, but same reasoning there.. I've got the Bryce patch, and I've got a Poser beta patch, not the newest one, as I really don't feel like downloading an 8 meg file with a 24k connection.. Either way, why would both programs not work at the same time if it were due to one or the other's lack of a patch? Mostly, I'm stumped, so I'll probably try the defrag/scandisk, though I shudder at how long that usually takes.. ugh. Thanks for helping, everyone... =) Rosh
Rosh, For what it's worth, I ran taskinfo (a program to check system resources, then took a hardcopy of Windows (normal), then while running Poser. Although it wasn't truly scientific due to delay in swapping between apps, it did show an increase of 40% of CPU and other processes while running Poser. The old Ctrl-Alt-Del only shows a few apps that are available. To get the real scoop on what your computer loaded at / during startup, do the following: Start>Run> Type in:MSCONFIG and click OK. Tell it CUSTOM, then select the Startup tab. You will be shown ALL the goodies that are loaded when your computer boots up. It may scare you!! Aside from a wheelmouse /pointer & graphics tablet (if you have one, you only need SYSTRAY & SCANREGISTRY! Uncheck all others and Apply. You may have to reboot. After reboot, try Poser or Bryce and let me know your results. This will at least tell if your machine was running too many processes in the background. Hope this helps, - Art -
For some unknown reason, every once in a while Bryce and Poser decide they're going to drop a "This program has performed an illegal operation" error on me when they're loading, so I have to reboot in order to run them. I haven't yet figured out a pattern to these errors, so I don't have any idea what's causing them, though usually they run fine when I first boot.. As a side note, when one starts doing it, the other one does it too, so I'm thinking it might be some sort of driver error or something.. but I'm really clueless.. Has anyone else encountered this problem or have any ideas how to fix it? I'm tired of rebooting every time I wanna run one of them.. It doesn't happen every time, just occasionally, but it really annoys me.. Thanks, Rosh
