26 threads found!
ARCHITECT | 3 | 129 | ||
ARCHITECT | 6 | 24 | ||
ARCHITECT | 2 | 14 | ||
ARCHITECT | 10 | 55 | ||
ARCHITECT | 3 | 11 | ||
ARCHITECT | 3 | 12 | ||
ARCHITECT | 3 | 14 | ||
ARCHITECT | 10 | 41 | ||
ARCHITECT | 0 | 5 |
(none)
ARCHITECT | 7 | 46 | ||
ARCHITECT | 5 | 19 |
63 comments found!
Thank you... I've been using the "edit dependencies / start-stop teaching" tabs for the MT's (open mouth/wide open) for the head and the body as well and now it's working without any problems.
Thread: Poser Pro 2014 SR 5 10.0.5.28445 - different obj-export? | Forum: Poser - OFFICIAL
...found a way to import the OBJ without fiddling around with the UVMapper...
Octane - Preferences - Geometry-Import - Load vertex normals = uncheck.
Don't know if there are any "side-effects" but it's possible to import the mesh this way.
...thank you.
The OS is Win 8.1 Pro 64 Bit.
Ok. I've tried to import the OBJ from Poser into 3DSMax 2015 - "ungültiger Normalenindex" - Max won't load the OBJ.
After that I've imported the OBJ into UVMapper Pro 2 (no problem at all) and saved the mesh with a different name.
I could import the mesh into Octane (but with no textures)
So it's obvious that the export from Poser doesn't work properly... :-(
BTW: I'm using the standalone-version of Octane - not the plugin...
M.
Thread: Charged but no download | Forum: MarketPlace Customers
...exactly the same here. I've bought Carlotta (Rhiannon) just an hour ago using PayPal. The PP-site directed me to Renderosity again after it said the payment was successful but the item was still in a state of "unpaid/download pending"
After a while (I didn't get a mail from PayPal which is normally in my mailbox immediately after buying stuff using PP) I thought that there was a problem with the payment so I started the paying once again. And again the item seemed to be "unpaid"
Now some minuted before PayPal sent me TWO mails and so I paid twice for Carlotta... But here on Renderosity it still says "unpaid/download pending".
So what? I don't want to pay for it twice. But after all I would be happy if I could download the things I paid for.
M.R.
Thread: OpenGL-Problems | Forum: Poser - OFFICIAL
it makes no difference if I open a CR2 or a PZ3. It does NOT happen if I load a standard character like a simple Vicky 4 into the screen. But when I try to apply a texture from the mat-poses (....for victoria 4.x) the mat-pose will load and then the character becomes black or dark-brown. The eyes are visible after that and also the nails.
The renders are fine even if I can't see what I'm doing in the preview screen. Doesn't matter if I use the standard settings or my own. It's in the preview screen only.
I've attached a screenshot from within the materials-room.
At the moment I'm using the Sreed-preview so I can see the textures.
A.
Thread: animations and textures....? | Forum: Poser - OFFICIAL
Oh, I did that. I know how to copy the nodes and textures.
But (in Poser 8) the "animation on" wasn't applied to the other material zones - although I checked it... I did some test-renders of different frames and some of the material-zones hadn't changed so I had to check the little key-symbol in the blender node one by one.
I've found that it's not possible to apply these nodes to all bodyparts and groups by simply using "select all" and "apply to all". If doing so you loose the animation of the texture (even if it seems to be "on" it doesn't work)
You have to select every single part of your character and apply the textures and toggle animation every time - one by one.
Maybe it's a bug in Poser 8. Or a feature. Don't know.
argh.... that doesn't work.
It gives me always the textures of bending value 2... even at frame 1.
....no it shall be a "gradual" change...
frame 1 to 100 - skin: 001.jpg
frame 150 to end - skin: 002.jpg
A.
Thread: Problem with Talk Designer | Forum: Poser - OFFICIAL
No. Sorry...
I've tried some different ...sub-formats (? - I don't know the english word for this) of wave-files (compressed, uncompressed, wave-mp3, 16-bit, 8-bit and many more) using conversions made with db-poweramp.
And none of the wavs will work.
same here...
I'v tried different versions of WAV-files on Poser 7and now 8 but it never worked for me.
Thread: Problems with P8? Bugs in P8? P8 crashes? Get help here! | Forum: Poser - OFFICIAL
Thread: Morphtargets and bones/bodyparts | Forum: Poser - OFFICIAL
