18 threads found!
Eagle_hawke | 1 | 72 | ||
Advisories: nudity
Eagle_hawke | 8 | 218 | |
Eagle_hawke | 8 | 121 |
26 comments found!
Ok it looks like that's working thank you. I'll post the final results when it's done rendering. Tho it may take a bit. Not too thrilled that I have to use this now anytime I want to use a V4 or M4 model but I guess it is what it is. Thank you for the help.
Thread: Problem with Superfly Rendering People!!!! | Forum: Poser - OFFICIAL
Ok I got yea, I loaded it to the right folder but I didn't know how to load custom PYC files. I figured it out tho, thank you. It's rendering now in Superfly, I guess we'll see if it works. So far what little is rendered isn't looking promising. I'll let you know in a few minutes.
Ok so I Download EZSkin3 and copied the EZSkin3.pyc into my Poser.exe location as the direction stated, but it said to run EZSkin3 and there is no EXE file and it doesn't show in my poser Scripts. How do I load this thing?
Thread: Making a door open Object created in 3dMax for Poser 9+ | Forum: Poser - OFFICIAL
Thank you all for your guidance. I will probably try the utility first off, but I think it will still pay to take the longer route in the long run. Thanks again to all of you, I'll let you know how it works out.
Thank you for responding, I can save it as a separate object but then It would be simply 2 objects one that I'm rotating. I was kind of hoping to have this act like a single figure with a specific Parameter dial labeled Open / Close, when I'm done with it. Or am I barking up the wrong tree all together?
Thread: Sims 2 to Poser? | Forum: Poser - OFFICIAL
I'll have to look into that, last I knew Milkshape converted Sims files to Sims2 and objects to Sims2 formats, but not the other way around. But I'll check out the site and see if they've fixed that.
I'm also not familar with SIMSPE so I'll check into that too. Thanks for the tip.
Most people don't use poser models in the sims because poser has a much higher quality to the models it uses and creates. So therefore it chews up way too much memory to use.
I've been searching for days now and I've seen nothing about it. Kinda stupid you would think with all the games you can convert to poser recognizable files... Halflife, Bridge Commander, Quake, you would have thought someone would have worked out something for the sims by now.
Thread: Character INJ does not respond V4.2 | Forum: Poser - OFFICIAL
no there's no RMZarh3 present. I have located the pz file in "RuntimeLibrariesRMMorphsRMZariah" where it should be, but it's just not loading.
Thread: Lighting in Poser 8 | Forum: Poser - OFFICIAL
Thank you!
The indirect lighting worked the way I was hoping. Where is the 'no interpolation' option, I cant seem to locate it.
Yes sorry should have been more specific whaen I said Translucent I meant transparency not set at 1.000
Yea, I've done bothe those things but setting the object to be ambient and useing indirect lighting doesn't cast the shadow properly, and just putting a light in a translucent dims the lighting so much it's difficult to get the proper effect.
I was actually hoping they added a feature that would actually make a prop like a cylinder a light. But I guess not. :-(
Oh well thanks for the suggestions.
Thread: Can anybody help with problem with Tailor 1.6? | Forum: Poser - OFFICIAL
I've tried Wardrobe wizzard and I couldn't make heads or tails of it. I actually just fout clothes converter and it seems to work but I need to feel out the settings a bit. Thanks for the help.
Thread: Creating bioluminescence with P6 shader nodes? | Forum: Poser - OFFICIAL
Ok, I've been over and over it and I cant get my props to mimic Little_Dragon's examples. They are incredibly impressive but I can't figure out how you do it at all. Can someone give me a step by step please.
Thread: Is there a way to make lights from a prop? | Forum: Poser - OFFICIAL
That Ambient is exctly what I'm looking for thanks! I've tried using the lights parented to translucent objects but I don't care much for the end results.Thanks though for the suggestion.
