28 threads found!
willyb53 | 1 | 424 | ||
willyb53 | 2 | 399 | ||
willyb53 | 17 | 1028 | ||
willyb53 | 4 | 503 | ||
willyb53 | 19 | 953 | ||
willyb53 | 20 | 926 | ||
willyb53 | 35 | 2022 | ||
willyb53 | 2 | 152 | ||
willyb53 | 2 | 146 | ||
willyb53 | 14 | 387 | ||
willyb53 | 4 | 161 | ||
willyb53 | 91 | 2706 | |
willyb53 | 7 | 230 |
792 comments found!
As a side/additional not, my tutorial: https://www.renderosity.com/freestuff/items/96406/saving-memory-and-diskspace-in-poser
contains step by syep instuctions on the process. note also that this prcedure works for v4 also and gives you a way to build a character library that can be applied to the base figure , not just a loaded one
Bill
Thread: WIP Freebie Conforming halter top for LaFemme (Original) | Forum: Poser - OFFICIAL
Another of the thre textures, this time with stretch material :D Local school colors, obviously "The Indians"
I will be submitting to freestuff either today or tomorrow
Bill
Thread: WIP: A Freebie conforming Pullover for L'Homme (original) | Forum: Poser - OFFICIAL
Just an experiment, can I make it look like a jacket or shirt :D
Bill
Thread: WIP Learning to do Conforming Dresses | Forum: Poser - OFFICIAL
Another Texture and Length Morph, Max and Min
Going to take a break from this and work n leggings for a while :D
Bill
Hybrids have their use :D I tend to avoid using the cloth room for renders, but when I use a hybrid, I use the 1 frame method to do the simulation. This avoids moving things from frame to frame. I am working on several LF (version 1) projects to finish them up since LF2 came out they will probably never be released.
Bill
It does not do too bad as is, but it can also be done by clothifying the hip (used as hybrid)
Bill
Thread: La Femme 2 Lite Now Available | Forum: Poser - OFFICIAL
LaFemm clothes do not work, LaFemme morphs do not work, so basicly there is no legacy content, do not feel like starting over :(
Bill
Thread: WIP = Convorming top for LaFemme | Forum: Poser - OFFICIAL
When I use morphs on a character, I spawn a FBM, give it a reasonable name,, zero the figure and then set the FBM to 1. Then copy morphs only requires 1 morph to copy to make the clothing fit the character. Makes a much lighter, faster loading item
If you know how to use what is provided in the software, you do not need clothes with many morphs included
Bill
And since I find LH/LF are very easy to rig clothes for, I have no idea why.
Bill
Thread: What you know now that you did not know then? | Forum: Poser - OFFICIAL
That was available in PP2014
Bill
Thread: 2023 Poser Free Stuff Forum Challenge | Forum: Freestuff
A Head morph for LaFemme, requires no other morphs
https://www.renderosity.com/freestuff/items/95209/eve-for-lf
Bill
Thread: Is there a way to turn off all lights in Poser 11? | Forum: Poser - OFFICIAL
One other way :D
https://sharecg.com/v/57963/gallery/8/Script/Light-Toggle
Designed so you could set up working lights, toggle them off and set up the render lights, and then toggle back and forth as needed
Bill
Oh Lord, am I the first?
Fangs for LFLH
https://www.renderosity.com/freestuff/items/94940/fangs-for-lafemmelhomme
Bill
Thread: Why is it faster to render a small object enlarged than render a close up? | Forum: Poser - OFFICIAL
I do not know about Poser internals, but other (older) software used octree culling, which is a binary search in 3d, in each step it examines all the cubes, and tosses out all with nothing in them. a small object takes more levels to find which cube(s) the object occupies
https://en.wikipedia.org/wiki/Octree
Bill
Thread: I started a long time WIP this week! | Forum: Poser - OFFICIAL
My Final (?) Character :D
LaFemme
Tee shirt from Jeans and Tee Shirt, Renderosity
Jeanz for V4 DAZ
My morph, makeup, Texture
Background from Free-images.com
I will continue to play with makeup etc, but as of now I have Two textures, one normal and one Tan (and not just color chip, full maps)
Bill
Thread: Save a modified figures head | Forum: Poser - OFFICIAL
