14 threads found!
6R | 2 | 104 | ||
6R | 3 | 168 | ||
6R | 3 | 54 | ||
Advisories: nudity
6R | 0 | 103 |
(none)
6R | 0 | 71 |
(none)
6R | 2 | 88 | ||
6R | 8 | 206 | ||
6R | 0 | 55 |
(none)
6R | 0 | 48 |
(none)
6R | 1 | 97 | ||
6R | 9 | 125 | ||
6R | 4 | 130 | ||
6R | 3 | 135 | ||
6R | 2 | 67 |
15 comments found!
Thread: Screenshots of games with DAZ graphics | Forum: DAZ|Studio
Yes, because I only use 2D pictures (renders) of the characters... I don't use them as 3D models people could reuse.
6R
Thread: prefs for Sketch render | Forum: Poser - OFFICIAL
Thanks for your help geep... So I knew they exist by default and we don't have to download them.
They are in Python folder !
I just had to copy the prefs folder into the runtime one.
Now it works ! ;o)
6R
Thread: DAZ Vador in... | Forum: DAZ|Studio
Thread: What a wonderful (Daz) world | Forum: DAZ|Studio
Thread: Torkeeper with aniMate | Forum: DAZ|Studio
To create an aniblock you don't need any lights or shadows !!!
Just V4 for example with different poses to "puppeteer" !
When you want to save your real animation using an aniblock on any character in a scene here you need lights (and shadows)...
It's true ! Depending on your aim : Render can be very long or not !
Create an aniblock and render a scene (picture or animation) are two different things.
Always make export tests with a small resolution 320 x 240 for example and just a few frames of the whole animation by taping 0 to 5 frames for example for the render !
You don't have to export the whole animation at the beginning...
If the first tests are Ok for you then you can export all ! And you can do something else during the calculation... :o)
A serie of images or an .avi file is the same (I think ?) relative to the duration... because Daz calculates and renders each frame in both cases.
6R
Very interesting to select the images before creating the .avi file !!! Thanks !!!
I do the same with Anim Shop 3 before creating an.avi file or a .gif file but it isn't free ! ;o)
6R
With the Tab "Render" (from Daz) : select Make Movie instead of Still image then render to mo vie file(.avi) or image series (.png files) !
6R
Thread: From 3D to 2D render (--> a very simple trick !) | Forum: DAZ|Studio
Thanks...
A guy on another forum has used my trick with Carrara Pro and a cartoon plugin : Fantastic result !!!
http://www.lostmarble.com/forum/viewtopic.php?t=12090
6R
Improvement :
I have tested with the default cartoon render of Daz : (With a rotation of the distant light and without rotation ! And with 30% ambient color then with 100% !)
It could be better with toonshaders in Daz !?!
6R
Thread: My first animation with the great aniMate plugin | Forum: DAZ|Studio
Thanks JenX...
And I needed 1 second to make this animation with the aniblocks !!!
(The render was longer !!!) ;o)
6R
Thread: Cute Toon Baby or Devil ? | Forum: DAZ|Studio
Thread: Dazdevil | Forum: DAZ|Studio
