2 threads found!
Albiejee | 10 | 171 | ||
Albiejee | 6 | 127 |
15 comments found!
Thanks, In my testing I think that the paired dials have made a lot of difference for my use of the product. The group dials have limited use as they are, though there is a great potential there. I may make an add-on that is just a whole collection of group dials and presets. I like the results so much that I'm going to create an add-on for the G3F version for sure.
Thread: LBG SoftBody Solution: G8F Chest Comming SOON! | Forum: MarketPlace Showcase
well sorry for the long delay. Life can get complicated some times. Now done and uploaded!!!!! It is now a matter of hours until you should see it in the store!
Quick update!
Ok, creating all of these dials is taking longer than I anticipated. I'm still working on this product and sticking to my goal of releasing a product that is a powerful tool and a time saver! I'm going to ensure that the result will be worth the wait.
Cheers,
First test of left side dials.
One of the uses of this product is to create a realistic soft body reaction for miscellaneous clothing.
I have often wondered the same thing, unfortunately I don't know anything about scripting, it is on my learn to do list but is in the distant future. I am open to any vendors wanting to create a script add-on or any kind of add-on for that matter.
Thread: LBG Soft Body Solution: G3F Chest | Forum: MarketPlace Showcase
Thanks for the positive feedback! I hope to make a few sets more for sure and as you say if sales keep me encouraged, there will be many more to follow.
LBG Soft Body Solutions This is the beginning of the future of natural poses. Are you frustrated with unnatural poses? Poses with arms or legs or props held at an unnatural distance away from the body? LBG Soft Body Solutions: G3F Chest is my first set in a series that will be focusing in on fixing clothing and body collision issues.
Lets start Posing the way we want to pose
Thread: DAZ-Studio Staff Picks 18th-25th May | Forum: DAZ|Studio
I havn't checked my messages in a while. Thank You!
It is an honour to be on the staff pick list :)
Thread: V4 underboob (low poly count?) any fixes? | Forum: DAZ|Studio
Mine does look like that when wire shaded. Rendered I can see the point between each poly. Maybe the Sub-D is what is needed.
Thread: Reality Render thread. A new beginning. | Forum: DAZ|Studio
Quote - Yes, the cylinder is a mesh light but everything in the scene is so dim. The image is heavily underexposed and the subject is squinting so there is no chance to see anything in those eyes. If you look at the arm you can see that it's completely flat, with no definition. That is also the effect of the lighting. Lighting cannot be done as if you are photographing a real life scene. The camera does not see like the human eye, in fact it sees less than half. So you need to complement the scene. Right now everything falls in darkness with no definition. You might consider more light and to adjust the exposure to brighten the image at least a stop.
Add some lights and have the lightsaber as a prop, not a light. Once you stop counting on the lightsaber as a source of light you will be able to focus on the lighting proper.
Light is reflected at an angle that is equal and oposite to the angle of incidence. So make sure that the mesh light is angled in a way to be caught by the camera. If you make it large enough and positioned slightly to camera-right it should work. Do some test renders at low res, it should not take more than a couple of minutes to see if the reflection appears.
Once you have the light in position you can let the render cook for longer.
Hope this helps.
Thanks, this does help alot.
I always seem to get stuck in a trap- thinking of what I want to see and not thinking of what the camera sees.
cheers,
Quote - A spotlight canno give you any reflection in the eyes, you need to have something to reflect in order to have a glint in the cornea. Use a meshlight positioned in the front of the subject. Scale it up if necessary
Thanks, I'll give it a try... So then not even an object converted into a light will give a reflection? or did I need a higher intensity on the light cylinder?
Thread: Poser 9 on sale for $69.99 | Forum: Poser - OFFICIAL
This looks like a great deal! From a daz-studio casual user thinking about getting Poser, What is the real world difference between Poser 9 and Poser pro 2012? I'd like to get into modelling and rigging but at the moment I am just a tinkerer...
