28 threads found!
DSQRD | 2 | 305 | ||
DSQRD | 9 | 752 | ||
DSQRD | 2 | 139 | ||
DSQRD | 1 | 220 | ||
DSQRD | 2 | 90 | ||
DSQRD | 8 | 283 | ||
DSQRD | 4 | 122 | ||
DSQRD | 3 | 135 | ||
DSQRD | 2 | 85 | ||
DSQRD | 6 | 163 | ||
DSQRD | 1 | 29 | ||
DSQRD | 2 | 17 | ||
DSQRD | 12 | 518 | ||
DSQRD | 3 | 283 | ||
DSQRD | 17 | 244 |
53 comments found!
Thread: Moving poser to a new Hard Drive | Forum: Poser - OFFICIAL
correction to second line
Since the only version of 11 that I have is a upgrade from poser 10 is it possible to use the upgrade to do an initial build of 11. Based on the fact my serial number v10 or v11 is no longer visible (accepted) I'm guessing not.
So first question is, Is poser 11 dead? and do I have to buy the side grade from 11 to 11 Pro? Since the only version of 11 that I have is a upgrade from poser 10 is it possible to use the upgrade to do an initial build of 11. Based on the fact my serial number v10 or v11 is no longer visible (accepted) I'm guessing not.
Is there anybody from Renderosity/ Bondware I can be talking to
I am using using W 10 64 bit and antiicipating a problem.
I purchased a new Computer and am trying to to load poser on to it, So I purchased and loaded poser 10 to the old comp. Then I purchased an upgrade from poser 10 to poser 11 but due to difficult I never installed it.Continous problems with the password) Then I downloaded the free version of poser 11 and installed it and installed it on the new computrr and using it in free mode. It will not accept my previously purchased Poser 11 Password.
I have all the documentation to show that I did indeed purchase this software but without a TS in Smith Micro I"m lost
Thread: I need some help creating a prop. This should be easy! | Forum: New Poser Users Help
Thread: hey i have a ? about poser pro 2014 animation | Forum: New Poser Users Help
What I would do for the walking problem is create your walk cycle, then go to the window/animation pallette in the command line. , In the first frame, I would create a pose for the upper body and arms then I would remove all future keyframes for those body parts.
Thread: Poser Pro 2014 sale - Worth it? | Forum: Poser - OFFICIAL
Thread: Simple coding problem in Python | Forum: Poser - OFFICIAL
Thread: I have recently had a catatrophy | Forum: Poser - OFFICIAL
Thread: Restarting an Animation Render | Forum: Poser - OFFICIAL
from the image pallette set the slider to frame 177, then from the animation menu hit make movie, set sequence type to :image files" and press start
Thread: PROBLEM STARTING POSER ON VISTA | Forum: Poser - OFFICIAL
Thread: Helllllllllllllllllp | Forum: Poser Python Scripting
So far I've learned how to run a Python script and ADP's script will render and run. I haven't tried this script with the change you've suggested but it may clean up the "save" ossue. Thanks
English Bob - Yes there is a button in the amination menu that does this BUT when I use that method the finished string of .JPGs seam to have tiny movement of lights whick make the finished animation appear to flicker. When I use the render menu to produce the .JPG's the resulting string doesnot display the flicker.
Philc - ADP001 sent a script that might work. Whether it works or needs some tweeking a can follow it enough to figure out where the next stumbling block is.
ADP001 - thanks for taking the time to create this script and adding the text notation.
The first thng i'll be doing is comparing the function calls to what is in the python manual to determine why I couldn't find them to begin with.
Thread: Can't figure out what hair this is! | Forum: Poser - OFFICIAL
I Know I Know
Its fake hair. I can always tell fake hair and this is fake.
LOL I had to do it
Thread: P5 cloth room problem | Forum: Poser - OFFICIAL
Thread: Survey Coupon valid for Early Access? | Forum: Poser 12
