343 threads found!
DocMatter | 2 | 206 | ||
DocMatter | 4 | 661 | ||
DocMatter | 6 | 349 | ||
DocMatter | 11 | 1188 | ||
2 replies with content advisory
DocMatter | 28 | 1372 | |
DocMatter | 1 | 260 | ||
DocMatter | 12 | 1105 | ||
DocMatter | 10 | 992 | ||
DocMatter | 13 | 985 | ||
DocMatter | 8 | 726 | ||
DocMatter | 10 | 1073 | ||
DocMatter | 19 | 931 | ||
DocMatter | 1 | 136 | ||
DocMatter | 5 | 740 | ||
DocMatter | 6 | 345 |
639 comments found!
It does. In this case, I found out, it turns out the vendor removed it from Renderosity and is selling it over at Daz instead.
Thread: Adding transparent BSDF to texture? | Forum: Poser 12
Thread: Need help making a smart prop | Forum: Poser 12
if you mean moving the origin, I tried that too. Put it in the center... same problem. Put it at the end... same problem.
My results are a little better if I parent it to her hip instead of her abdomen, but it still moves.
Thread: V4 and M4 lo-res figures no longer loading | Forum: Poser 12
Got a 17k to work, but a 4K still blows up. I'm gonna call it quits for the day while I'm ahead. Thanks for your help!
Okay... Ive got a new problem with the lo-res figures. They work great in Poser, but for some reason, if I try to use them in Daz, they blow up when I try a pose.
In the pics (Poser on the left and Daz on the right) is the exact same figure with the exact same pose. I've tried lots of different poses and no matter what, she blows up in Daz. I've tried it with and without the dress as well. Same result.
Suggestions?
Thread: Using Daz Studio scenes in Poser 12 | Forum: Poser 12
I think I'm going to take the plunge and try and use it in Studio. I was reluctant to go this route because it seems I have to recreate all my saved figures (V4 and M4 with textures and morphs) in Studio if I want them to look right.
Thanks for everyone's suggestions!
The script looks like it might work, but I'm on a Mac and the last I heard, scripts aren't working in Poser12 for Macs yet. Hopefully I'm wrong.
Its the Back Alley scene and add-ons by Christophe3D.It's doable, but there will be hoops to jump through. I've heard good things about this script:
https://www.renderosity.com/rr/mod/bcs/duf-prop-converter-for-poser-12/153019/
What scene is it?
I tried the editing the cr2 method and it worked great (no morphs yet, but I'll try that later.)
Thanks for all the suggestions folks! I'll try the setup room again when I have time... it still scares the hell out of me! ;)
Primorge -- Thanks for the blank files. I tried what you said but have a feeling there's a lot more I have to do in the setup room... as seen in the pic.
Any joint I move results in the weird effect you see here.
Thread: Genesis 8 Cross-figure Resource question | Forum: DAZ|Studio
Thread: Weird lighting problem | Forum: Poser 12
Turns out that just replacing the spots and starting over did the trick. I don't know why the original ones made it white, because I deleted them and created new ones with exactly the same properties and now it works fine.
Weird!
Thanks for all the suggestions!
Thread: "Unavailable" content | Forum: MarketPlace Customers
