10 threads found!
Dore | 4 | 18 | ||
Dore | 2 | 162 | ||
Dore | 6 | 95 | ||
Dore | 6 | 115 | ||
Dore | 4 | 216 | ||
Dore | 3 | 148 | ||
Dore | 7 | 237 | ||
Dore | 5 | 120 | ||
Dore | 2 | 115 | ||
Dore | 1 | 80 |
10 comments found!
As suggested by someone off line, I backed everything up and then reinstalled the P5 program. That fixed the problem. Watching the backup I discovered that somehow, I have no idea how, I had ended up with two copies of the P5 executable file with differing URLs and suspect that was the root cause, just confused the machine I guess. Thank you to those who offered suggestions.
Thread: Opening PZ3 files in P5 with P4 also on the drive | Forum: Poser - OFFICIAL
Unfortunately, no. I should have said so in my first response but neglected to so say. I tried it several times without effect. Thank you for your attention, I guess I will just use the "import" route for the time being. David
PhilC,
Thanks for the response. I tried that but Win Explorer seems to be the root of the problem, it only lists P4 for some reason. However, I tried importing a PZ3 file into P5 and that seems to work okay, so there is a work around.
Thread: Injection morphs in P5 | Forum: Poser - OFFICIAL
Oh, I got it. Yes I do have the Body and Head files under !DAZ/Victoria 3. Just for the heck of it I dug up my download archive and reinstalled the V3 Head and Body morphs. That didn't change my inability to use the three morph injections listed above. Thank you for your thoughts, if you have any further idea as to a cure or work around I would certainly appreciate them.
Thank you for your futher comments. I started P5 from scratch, added V3 SR1 from DAZ People, and then tried to inject the V3 Anguish morph (don"t recall where I got that) from Poses - hung machine (little watch never goes away, eventually get "Poser Not Responding". Quite P5 and started over. Did same thing with same results with Trinty and !Faith FreeGal V3 morphs both obtained from Renderosity Free Stuff. A quick look through the libraries suggests that I think all the injections morphs I have purchased from DAZ work, didn't have time to see if there were any purchased injections morphs from Renderosity Marketplace and check whether any such work or not. Any suggestions?
Thread: V3 morph dials problem | Forum: Poser - OFFICIAL
I would appreciate it if someone could be a little more specific about how to use Dial Cleaner. How does one feed a new model "into it"?
Thread: Is Victoria3 supposed to load in Poser 4.0.3? | Forum: Poser - OFFICIAL
Thread: Poser 5 Memory Dot disappearance | Forum: Poser - OFFICIAL
Thread: P5 Texture Maps | Forum: Poser - OFFICIAL
