7 threads found!
Floydd | 10 | 51 | ||
Floydd | 3 | 27 |
1999 Sep 11 10:12 PM
Floydd | 3 | 14 |
1999 Sep 03 9:01 AM
Floydd | 4 | 28 | ||
Floydd | 0 | 7 |
(none)
Floydd | 3 | 47 | ||
Floydd | 0 | 31 |
(none)
63 comments found!
Nod did a P4 texture map for a "Looks Like Scully". I have not checked, but would guess it is at PFO.
Thread: Getting Reflective Bryce - Vue Water Effects in Poser | Forum: Poser - OFFICIAL
jhoagland DID do a great job on the Indoor Pool prop. I'm not sure I understood what exactly you meant by "adding a Chrome metal map to the water's Transparency Map". Are you using the Chrome as the Reflection Map or actually mixing the artwork and using it with the existing Transparency Map for the water? Nice improvement either way.
Thread: poser 3 and 4 question | Forum: Poser - OFFICIAL
There's a thread from yesterday that seems to say no. http://www.poserforum.com/messages.ez?ForumID=12356&Form.ShowMessage=33652
Thread: Primal Fear | Forum: Poser - OFFICIAL
Thread: Help with the Poser4 Woman | Forum: Poser - OFFICIAL
How did you get rid of the winder on the side? (am I thinking of the right model, the joke teeth with the wind-up crank on the side?)
Thread: Another Leaf by Niggle | Forum: Poser - OFFICIAL
That's it - a reference to the short story by Tolkien concerning a compulsively redundant quest for perfection in an otherwise inconsequential act. (IMHO)
Thread: Rendering in Wireframe mode..?? | Forum: Poser - OFFICIAL
Thread: OT-help with storage for Poser stuff | Forum: Poser - OFFICIAL
My HP CD-R/RW has never had any problems with the CD-R discs but HAS lost data when doing the Drag&Drop funtion on the CD-RW's. My version of Direct-CD is about a year old though. btw - Adaptec also has a free utility at their site that will allow any (high speed) CD-ROM drive to read their CD-RWs. Being able to copy directly from the CD-ROM drive to the burner has sure made my file management a lot faster & easier.
Spike - btw, I gave your method a shot and liked the results but my wireframed image rendered out with nasty jaggies. I guessed that this was because the map was just too small. For your piece, did you use the Poser default template from the CD and soften the edges with the transparency controls, or did you create a larger, hirez map template? -floydd
4th way: Someone (coldrake?) posted an image here in the last couple of days where they used the default UV template as a Transparency Map - resulting in a wireframed render.
Thread: Rookie | Forum: Poser - OFFICIAL
Don't be taken in. I feel sure this is Coop's new undercover screen persona to facilitate the gathering of consumer psycho-data. :) but just in case... Awesome Dude! It rocks for a first post!
Thread: Is there a program you can Put all frames from poser into and add Audio ect? | Forum: Poser - OFFICIAL
Thanks for the suggestions. I'll look around. S.R. - my whimpy-puter won't handle 30fps so it's not a program requirement for my use. -floydd
Thread: TransGirl test | Forum: Poser - OFFICIAL
Thread: Looking for Dr. Crusher, Gillian Anderson, and Cindy Margolis | Forum: Poser - OFFICIAL
