12 threads found!
Idol | 3 | 20 | ||
Idol | 2 | 30 | ||
Idol | 1 | 10 | ||
Idol | 3 | 21 | ||
Idol | 10 | 80 | ||
Idol | 3 | 39 | ||
Idol | 2 | 14 | ||
Idol | 2 | 37 | ||
Idol | 1 | 11 | ||
Idol | 4 | 57 | ||
Idol | 7 | 52 | ||
Idol | 10 | 62 |
22 comments found!
I have just try SP2, but still I only get a cube with the box normals facing inward. Strange. Has any one used the plugin sucessfull? Marcus
Thread: Windows 2000 | Forum: Poser - OFFICIAL
Dennis, do you have the latest patch for Poser4? I think there was a note in the upgrade to 4.0.3 about its now possible to run Poser with very mutch ram.
Thread: realistic faces | Forum: Poser - OFFICIAL
There are some good, photorealistic textures here at the Posers freestuff page. Very mutch depend on the texturing and the lighting as well. The eyes are very important to, so experiment with transparent and higlights for the eyes. Dont forget to use the bumpmaps! /Marcus Thorell
Thread: Texturing a new (obj) figure | Forum: Poser - OFFICIAL
Thanks! Now I'm close to a solotion on this. I usally work with MapMagic, but mapmagic have a "Floating point division by zero" error when I try to tile the groups, but it works fine in UV Mapper, and UV Mapper looks to be little more modern.
Thread: Only backfaces visable-problem | Forum: Poser - OFFICIAL
I was wrong! On the chest only the backface was visible. I thougth that should be no problem, when I render it it will be ok... But now, when I render it its looks like the ambientcollor is much lighter then it should an that becous of the backface.
Tank you for all your help, but now I have redone the figure so I think I will be ok with it for now.
I used the "Objaction Two-Face" at the .obj and get it work fine (the left foot dose't work but I can live whit that). But I had to remake the figure in poser (all the joints, IK's and so on was lost). The program you have, do it make the faces right at the .obj, .crs or .pz3-files?
Thread: Backface only? | Forum: Poser Technical
Yes, it's right when I render it. I put this question at the Poser forum as well and I the problems seems to be solved now.
Thread: IK at a new figure | Forum: Poser - OFFICIAL
Thread: So Adobe buys Carrara!! | Forum: Carrara
I think Carrara could be strong and even better in the hands of. Not everything that Adobe makes are expensive. Indesign, for example, is not. So if Cararra gets better and going up strong against leading 3D-software on the today-market, I think Carrara is worth some more money. /Marcus
Adobe have never made any bad softwhere, yet. So I think Carrara can be very greate in the hands of Adobe. Just wounder what happends with Poser then? If Poser is going to an other company, then we maybe never going to see Poser and Carrara integrated (that was a dream for me to see some day). /Marcus
Thread: Canoma now owned by Adobe, is Poser/Bryce far behind? | Forum: Poser - OFFICIAL
I hope some company will make Poser and Carrara working together, and it's not bad if they even integrate Bryce to...
Thread: Can not import scene into 3DStudioMax with ProPack | Forum: Poser - OFFICIAL
