18 threads found!
JIMMYJOHN | 13 | 331 | ||
JIMMYJOHN | 18 | 417 | ||
JIMMYJOHN | 39 | 1841 | ||
JIMMYJOHN | 14 | 333 | ||
JIMMYJOHN | 37 | 618 | ||
JIMMYJOHN | 11 | 237 | ||
JIMMYJOHN | 11 | 218 | ||
Advisories: nudity
JIMMYJOHN | 3 | 159 | |
JIMMYJOHN | 4 | 136 | ||
JIMMYJOHN | 6 | 160 | ||
JIMMYJOHN | 11 | 367 | ||
JIMMYJOHN | 5 | 114 | ||
JIMMYJOHN | 12 | 131 | ||
JIMMYJOHN | 9 | 272 | ||
JIMMYJOHN | 7 | 183 |
153 comments found!
Uh, bad news but at least I now know where the problem comes from... Thanks for taking the time to help me, I'm grateful.
Thread: VICTORIA 8 REDDISH | Forum: DAZ|Studio
OK thanks. It says: General release 4.9.4.117 SDK release 4.5.0.114 Public beta 4.9.4.122 Private beta 4.10.0x Does it make sense ?
Hi RHaseltine, not sure which version :( or I don't know where to look I says DAZ 4.9 pro, no other numbers behind like 4.9.2111 or whatever. Can that be the problem ?
You may be right but :
Elisabeth V8 IRAY with standard light. Can't be right, can it ?
Thread: Basic question about texturing | Forum: Poser - OFFICIAL
OK, found the problem: 3DSMAX doesn't edit geometry created in AutoCAD.
I first have to import the .dwg, save it as a .max file then reopen it before it can be edited.
Thanks for your help!
Hi RorrKonn,
3DSMAX UV Mapping (or unwarp UVW as they call it) seems to be the way to do it: I tried it with simple examples and it worked perfectly.
But not for something as complex as I'm trying to make: 3DS doesn't create the UV template I need...
No, those are primitive 3DSMAX boxes of different sizes, jus made to illustrate my point.
But I made a much more conplex geometry in AutoCAD (then imported in 3DS), and was looking for a way not to make different instances of objects meant to receive the same texture.
But it looks like this scaling problem will force me to get (is i a freebie?) and learn UV Mapper.
Thanks to you all for your useful answers.
Thread: FYI I'm going to go away for a while. | Forum: Poser - OFFICIAL
Bad news... for sure, a lot of us here will miss you greatly.
Let's hope the problems can be sorted out so we can have you back with us ASAP.
Hi RorrKonn,
Not using any mapper, just working ond the advanced section of the material room:
so if I change the scale of one block, it changes the other automatically.
PS: the geometry is created in AutoCAD and 3DS MAX.
Of course, in 3DS, I could attribute a different mat for each part. But there are so many parts (and I reckon 3DS limits the application of different mats to 26), I just wanted to know if there were another simpler way of making this.
PS not sure I'm very clear in my explainations...
Thread: Material room - Texturing - Shaders - TUTORIAL | Forum: Poser - OFFICIAL
Wow, just WOW!!! I'm in awe...
The car & bike just look out of this world.
In a couple of centuries, if you keep on sharing your knowledge to me, I may be able to render something appproaching that quality. Hopefully...
if you're interrested, i'll keep you posted on my improvements. And if you don't mind, carry on asking for advices;
PS: mentioning the "bad quality" of the tyres was meant as a joke (and eventually a compliment).
No problem when it's left to SPHERICAL MAP.What am I doing wrong?
- Next step will be to try your MATMATIC GLASS on the windows.
Cheers!
@Boni I love it too! But the tyres (a good thing, it proves our friend Bagginsbill is human after all ;-)
