15 threads found!
Jin_Yindao | 0 | 138 |
(none)
Jin_Yindao | 10 | 463 | ||
Jin_Yindao | 2 | 138 | ||
Jin_Yindao | 2 | 268 | ||
Jin_Yindao | 5 | 389 | ||
Jin_Yindao | 3 | 303 | ||
Jin_Yindao | 14 | 299 | ||
Jin_Yindao | 1 | 86 | ||
Jin_Yindao | 3 | 168 | ||
Jin_Yindao | 5 | 287 | ||
Jin_Yindao | 10 | 242 | ||
Jin_Yindao | 4 | 161 | ||
Jin_Yindao | 6 | 265 | ||
Jin_Yindao | 5 | 105 | ||
30 comments found!
I have used poser for many years, doing my best to create everything my pictures contain. Working with Lafemme is a pain as if you try to fix a morph for me anyways it goes crazy. I am not am not dumb but have difficulty with interfaces which is why I like poser as it is simple, even though blender has a lot more to offer. More so since I spent three months in ICU for oxygen derivation where I lost a lot of memories.. What I do not understand is why the designers cannot make things that actually work easier. We have a hair room which would work if there were tools that could assist in designing the style. but having to guess where the hair will pull or bend is not efficent. Having a brush or comb that you could place the hair where you actually wanted it instead of having to guess. I use an inexpensive program to create items or to morph figures because again the interface is simple. but when I carry the figure back it looks nothing like what it looked like in Silo. I really cannot understand why this happens. Both programs have the same import and export and the morph works, just not the way it was designed. One last thing, update the manual and explain how to do things with examples.
Dive into Fantasy and Ride the Waves
I have many scenes in my head, but non of those are on paper.
I have yet to learn to bring those to life.
The ones that I give life, are not those I see
Thread: is something wrong with me or is it poser? | Forum: Poser 13
30 verts, density 20281(6,307} hairs support told me to redownload and reinstall to if that will help with the flickering screen and crashes. let you know if that works. oh checked the memory and all 128 gigs are working and the titan-x has 12.
Again, am in error, but did warn of memory problems. Above I said that followed your instructions which showed the legacy room. To me that is the default setting as do not like the results when using the other settings so I should have stated that. Right now was trying to run the simulation again and poser has been hung up on draping for the last few hours and the screen has just gone white with up in the left side it says, "poser not responding"
the hair was done in the hair room. just showing what happens in both rooms. the ribbon was done in the cloth room. sorry thought that would be a given.
thought replied to this earlier, below are images that were asked for. Already showed the explosion in the cloth room so now will show the others that mentioned above after I followed the instructions of Red Phantom. Going to probably delete the upgrade, redownload and install. may have to do it for several programs it seems to have corrupted. Poser only thing updated.
Thread: poser update crashing poser | Forum: Poser 13
thanks
Thread: Show your Poser 13 renders! | Forum: Poser 13
hi this is a firefly render of my first article of clothing that made for a window display. manikin is lafemm 2 pro. item created in silo. would like an opinion as know am not as good as most here.
Thread: Cloth room tutorial for moving figure | Forum: Poser - OFFICIAL
am using poser 13 on win-11 have 64 gigs of memory.
Thread: poser breaking poligons apart on export. | Forum: Poser - OFFICIAL
solved the problem by unchecking all the boxes in the export window.
and yes all seams were welded before exporting from silo.
sorry joined discussion a bit late, but I have the same problem with clothing in the cloth room. have 20 frames to drape material, have a simple walk pattern created with poser. figure starts out fine, about frame 45 the clothing goes every which way, in all my other posers had no real problem in cloth room. If you reset simulation, the cloth will not return to normal shape or zero position so it has to be deleted and re-imported.
Thread: copying repeated animated scene | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
am not as tec savvy as most here, but maybe can help. if you create a movement for one figure then you can save that movement as a bvh file the apply it to another figure. You might have to do a few alterations, but it works. Hope this might help
Thread: Installing Poser 11.3.816 | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Have learned a long time ago to keep runtimes separate from poser content folder. also when installing a new version of poser I will rename the old content folder so the new content will install in a separate folder then use a program such as in merge to see what is different and what is the same. This way old content is not lost or over written.
Thread: I encountered some strangeness when downloading new files | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Microsoft edge gives the same problem as firefox. even if disable anitvirus have had to try over 20 times to download
Thread: creating prop lights | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
where would this node go in physical surface node?
Thanks, will play with it and see what happens. if it works, you have solved a problem that have had for years.
Thread: Things you want to play with in Poser... | Forum: Poser 13
