49 threads found!
L&A | 3 | 52 | ||
L&A | 12 | 81 | ||
L&A | 0 | 9 |
(none)
L&A | 0 | 3 |
(none)
L&A | 2 | 9 | ||
L&A | 0 | 2 |
(none)
L&A | 7 | 42 | ||
L&A | 0 | 3 |
(none)
L&A | 2 | 38 | ||
L&A | 4 | 19 | ||
L&A | 2 | 9 | ||
L&A | 2 | 6 | ||
L&A | 1 | 22 | ||
L&A | 2 | 14 | ||
L&A | 7 | 57 |
79 comments found!
high key??? don't know what it means......but what we are going to shoot...still is undertermined really....it would be more object but perhaps ppl too....
Thread: for DrmzRmyne - creating drops and ripples | Forum: Photography
pipette is french!!!! german and french are quite close in fact I guess. from your explaination, I never thought it would be that simple. THx for sharing...it still is a very nice one and it's still magic...you can have the best tool on earth...if you don't know how to use them.... thx for the help.
OK!!!! the color was what amazed me the most....I wonder how it was possible to have such colors. but if it's not too much to ask. what manipulation did you use to get that color?
Thread: Stone Wall | Forum: Writers
Thread: Microsoft Agent Tips??? | Forum: Poser - OFFICIAL
Don't use too much color. I think you'll have to transform it in 256 colors and in thiscolor, you'll have to include a transparency color. So you'll wont be able to put some very colorful and detailled scene. I tried an explosion and it was awfully ugly. I think that you might have headache. I tried once to create one and was very dificult. Good luck, you'll have many anims to do.
Thread: UV Mapper | Forum: Poser - OFFICIAL
I've got a solution but maybe you'll don't like. You need 3dsmax you apply a cylinder uvmap on the arrow and a planar on the tip and a box uvmap on each feather. So you'll have a each piece seperately in UVMapper. If you don't have 3dsmax send me the file and I can do it for you it's not long.
Thread: Need lighting help for first post | Forum: Poser - OFFICIAL
If you're in Poser the thing at the upper left corner is a sphere with little sphere attatch to it. Every dot is a light an by clicking on it you can change the color. You can also see the lights in the menu under the scene where you can select body parts and props. If there's only one I don't know, sorry!
Thread: New Model Help... | Forum: Poser - OFFICIAL
I don't know how to use anim8or, but I know this would be a very easy char to do in 3dsmax. This is cartoon so there's no a lot of details. Using primitives for this model will be more than enough to do the char. The head is made up with 4 sphere and two cylinder. One sphere for the head, an modified sphere for the nose and for the ears and two modified cylinders for the eyes. Hands is made up with a cylinder with box attatch to it. The body is more complex to do but it seem easy. Depending of your skill you'll probably made this up in about 5 hours, mapping include. To do them animatable in poser is very hard. Sorry if I'm negative, but I'm unable to do it. Unfortunatly, someone has try to show me, but I still don't get it right. Sorry! Hope this will help ya!
Thread: Animation Quality | Forum: Poser - OFFICIAL
no timeteo a tv doesn't have a 4:3 ratio. For the render I choose current render settings, but it look like it mess anyway.
VirtualSite: your method is long but ther's still a problem. Premeie wich I have mess the viedo too. It look like evry 3d program mess my videos. An b btw don't use 640x480 for a tv is not a 4:3 proportion. It's just a tip. tasmanet: Usually I think it's 27 fps I check the information and I,ll post a reply here Little_dragon Full frmae is ugly. Tanks all.
Thread: Sorry the image didN't upload | Forum: Bryce
Thanks! I really appriciate your help. The scene around will be improved and I want to send the final image to the contest at Bryce. I'm think doing a mountain with a drgaon head with the jaw open. It could be an ...sorry don't know the English word... let's say living place of the devil. And maybe I'll put some lightnings in Postwork. Anny other ideas or comment are welcome. Always ready to improve.
Thread: Joint Help | Forum: Poser - OFFICIAL
Thanks every body esp. SAMS3D. Even if I was able(I don't know how) to fix the prob, your tut look like very good and could be helpful. PhilC I'll finish the work and put a message here to show you the result. Thanks
Thanks PhilC but unfortunately I don't have enough money to spend on buying CD's. You fix my right wing and I'm trying to do the left one but I never learn how to do my joints. I used the same wing but with a reflection and try to fix the joint but am unable.
Thread: Alladin style Genie | Forum: Poser - OFFICIAL
Thread: Poser Problem In Max | Forum: Poser - OFFICIAL
Thread: Photography studio | Forum: Photography
