17 threads found!
LarryWheeler | 3 | 336 | ||
LarryWheeler | 2 | 418 | ||
LarryWheeler | 2 | 249 | ||
LarryWheeler | 2 | 128 | ||
LarryWheeler | 8 | 274 | ||
LarryWheeler | 14 | 355 | ||
LarryWheeler | 5 | 174 | ||
LarryWheeler | 5 | 125 | ||
LarryWheeler | 6 | 185 | ||
LarryWheeler | 3 | 170 | ||
LarryWheeler | 2 | 154 | ||
LarryWheeler | 6 | 139 | ||
LarryWheeler | 11 | 254 | ||
LarryWheeler | 4 | 210 | ||
LarryWheeler | 5 | 139 |
24 comments found!
Thread: Black spots or shadows when figures are touching. | Forum: Poser - OFFICIAL
The spots or shadows are subtle but for me they are not clean looking. I could fix with photoshop but I feel like theres something in poser I could correct. Thanks.
Thread: I'm back again with same old problem…Someone please help. | Forum: Poser - OFFICIAL
I couldn't figure out the problem with not having permission but I did get all the morphs to work. I used daz install manager to install all my m4 morphs then i manually installed all the v4 morphs. It took a while but I manually put all the files in the correct runtimes in a separate folder that daz install manager didn't have access to. The initializations worked for v4 and now all the morphs are working correctly. Some how daz install manager was making the file so I didn't have permission. But everything is working now. Thanks for all the help.
Ok I've gotten all the morphs for M4 to work. I just used the daz install manager as ambient shade suggested. I also initialized the figure in the runtime folder it was placed in. All figures and morphs are in the same runtime folder via daz install manager. But now when I click on the DzCreateExPFiles-V4.command for the v4 character I get a message like this.
I am unable to initialize v4 and access her morphs. Any one know how to fix this?
I'm using Poser pro 2014 on a mac…I have been adding my content with the add runtimes tab above my poser library. I have gotten all the morphs and base figures in the same folder but the morphforms dial doesn't show.  I've tried everything. I've initialized both figures a thousand times. Should they be in the actually Poser pro 2014 runtime folder? As of now they are in a separate folder in my applications.
Thread: poser crashes too much...Help!! | Forum: Poser - OFFICIAL
Thread: Hello...I'm back again. I need help with poser. If anyone can solve this your aw | Forum: Poser - OFFICIAL
Ok I tried that...I unchecked the binary morph targets and opened up a brand new project. But still the same result. The dial will go left to negative but not to positive. Everything seems to be still locked somehow.Â
Â
This is a dumb question but i've always been confused on where to put the files to make them show up. I usually just put them in a folder I created and click add runtime to library. All the other props and morphs work fine but the morps ++ don't work. so far thanks for your help.
Thread: So I've tried everything I can but I'm back with the same problem...Can someone | Forum: Poser - OFFICIAL
Ok I am using a Mac OS X version 10.7. Poser is in my applications program. Victoria 4.2 is in a seperate runtime as V4 ++ and the morphs
Thread: Simple questions for poser nubies.... | Forum: Poser - OFFICIAL
I'm using a Mac. So if you download the file and drop it into the poser runtime folder will it autiomatically show up in the library. I've always been confused on getting the files to show up with out using the add to library button.
Thanks...Just by clicking the add to library button in Poser 9 will that add all the files I need for the characters or do I have to add them to the actual folder manually.
Thread: Victoria 4 poser help!!!! | Forum: Poser - OFFICIAL
V4 is in the downloads folder where it was origionly downloaded and the runtime is in the poser 9 folder...
Thread: Renderosity log in information not working in poser 12 | Forum: Poser Technical
