Thu, Jan 23, 6:09 AM CST
Subject: So I've tried everything I can but I'm back with the same problem...Can someone
LarryWheeler ( ) posted Wed, 30 October 2013 at 6:39 PM · edited Wed, 14 August 2024 at 9:53 PM
I have downloaded Victoria 4.2 and Victoria++ morphs but I can't seem to get the morphs to load correctly. After I click to load the dials appear but there is no response. Like the pregnant morph will load into the parameters tab but when I move the dial nothing happens. The shoulders move a little but that's it. I even go to my V4 folder and run the initalization but when I go back and load V4 none of her morphs work. It's like her body is still locked or something. Everything I do doesn't seem to work. If anyone can help I would apprecieate it. Thanks.
hborre ( ) posted Wed, 30 October 2013 at 6:58 PM
Okay, I believe that we may have asked before, where is Poser installed and which OS are you currently using?  Are the morphs installed into the same runtime as Victoria 4.2?
LarryWheeler ( ) posted Wed, 30 October 2013 at 7:04 PM
Ok I am using a Mac OS X version 10.7. Poser is in my applications program. Victoria 4.2 is in a seperate runtime as V4 ++ and the morphs
hborre ( ) posted Wed, 30 October 2013 at 9:44 PM
I am not familiar with the MAC environment but I assume the procedures are relatively the same under a Windows OS.  When installing V4, there is an primary initialization to prep the model for morph channels.  Then install the Morph++ pack and rerun the initialization again to prep the model to receive the pack.  Load a new V4 into the scene and inject the morphs++.  Everytime a new morph pack is introduced, the initialization must be rerun.  To check if the initialization had taken, load a base V4 into the scene and look at the Parameters tab for a new channel entitled Morph++.  Everything should work after injecting the pack.  Do not attempt to add morphs to a V4 model already saved into your Library or .pz2 scene prior to installing the Morph++ pack, those models would not have the appropriate channels established to accept the pack.
