7 threads found!
LazloHollyfeld | 0 | 53 |
(none)
LazloHollyfeld | 8 | 122 | ||
LazloHollyfeld | 3 | 88 | ||
LazloHollyfeld | 1 | 748 | ||
LazloHollyfeld | 8 | 194 | ||
LazloHollyfeld | 1 | 92 |
7 comments found!
Attached Link: http://stavchansky.net/work.php?wID=4&cat=2
Thank you for including my photo of the espresso cups in this wonderful collage of photos from some very talented photographers. I consider it an honor and look forward to contributing more of my work in the future!Thread: Lastweekinthegallery Week 51 | Forum: Photography
Thank you for putting my image in this week's feature. Honestly, I did not expect it to make it up there with all of the talent here. You've given me more reason to continue photographing things that interest me. . . I look forward to sharing more of my work with the whole RR community for years to come :)
Thanks!
Thread: Grouping separate objects, not polygons, with the grouping tool. . . | Forum: Poser - OFFICIAL
Thanks for the informative link, Dr. Geep :) However, after reading it, your example makes use of a two polygon prop. My prop (as it enters the setup room as one object) contains thousands. I'm still unsure how I can select individual objects to be grouped, instead of polys. Thanks again for your kind help!
Thread: Importing 3DS Character to Poser | Forum: Poser - OFFICIAL
Thanks for the prompt response, and for the guidance. I did what you said, and installed the plugin, only this plugin does not work with 3DSMax 6. Do you know of any other conversion programs that may work with 3DSMax 6? Thanks again for all the help!
Thread: Waterdroplet Kit for Photoshop. | Forum: MarketPlace Showcase
I made it in Photoshop 7 for PC, and the testers worked on it with the Mac and said it worked. I have not tested it in Photoshop CS, but assume it does work.
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=28392
And another image. . .Thread: Jerky motion when applying walk designer to a figure with a path. . . | Forum: Poser - OFFICIAL
Thank you both for your help! I updated my Poser5 package and everything is fine. I appreciate your time and help.
Thread: Last Week in the Gallery 33 | Forum: Photography
