3 threads found!
Mhawke | 13 | 293 | ||
Mhawke | 3 | 133 | ||
Mhawke | 6 | 259 |
7 comments found!
You have achieved some very realistic lighting effects on the skin.. still struggling on that one for me - always a challenge! You should post this to your Rendo gallery as a larger jpg image.
I've never been succesful with sss in C, share some setting when you can.
Thread: Boat wake on water? | Forum: Carrara
Quote - The link doesn't work I'm still in the dark on this one..
The post is 6 years old ... link probably went dead years ago.
Thread: Models with animated dynamic cloth not importing into Carrara 6 Pro? | Forum: Carrara
Thre are new mesages posted on the DAZ|Carrara forums stating that Transposer is NOT part of the C6 product or upgrade.
You can purchase Transposer 2 for C6 as a separate product (add-in?) - listed at $99.99, but currently discounted. It will NOT work with Poser 7 files.
Bummer!!! Personally I thought it should have been included with C6 Pro - or upgrade, since It alreadty came with C5 Pro.
Thread: Carrara 7 Wish List? | Forum: Carrara
Quote - > Quote - Hi, You can actually undock the pallets, just click the button I circled. I don't know about the Poser Import, but I remember reading the situation you describe was fixed (it must, because you can not use it as it works that way). Have a nice weekend to discover the fun of Carrara!
Yeah but you can't drag the pallet after you unlock it outside or off the main doc window.
Got to menu options file.preferences, select general from the pull-down menu.
The last item is for multiple monitor settings. Check the Split option, and be sure both monitor symbols just below that are selected. Then close and restart Carrara.
Undock properties pal by selecting the large arrow at upper right.
Point click on title bar and drag to other screen.
Should work same for sequencer.
?? Think I rembered that right - give it a try.
Thread: Animation Timing | Forum: Carrara
Associatedfx web store has been off-line since March. I've emailed several times but no response.
Other than what was suggested previously (select keyframes and drag), there is not much of an option (that I am aware of).
I'm hoping C6 will fix that with Non-Linear Animation - only time will tell.
Thread: Galleries, today's top rated?? | Forum: Community Center
Thanks to all for the replies and comments! This clears up most of my questions.
I realize there is a potential for abuse in any ratings systems, wether it is biased by the "buddy system" or not, but it is still nice to get feedback on your submissions and some competion (today's top list or top100, whatever) provides goals and the gives the artist a sense of accomplishment, or recognition, when reached.
Art should be pursued for it's own sake, as opinions will always vary and should not influence the artist from his/her visions. But a lot of what is posted here requires as much technical skill as artistic, and the feedback and tips on the techincal side can be invaluable to the nuby.
Would I like my art to be rated in the top 100, sure, but only if it deserves it and not just as a result of a popularity contest.
Thanks again.
Thread: Poser 7 crash, won't load!! | Forum: Poser - OFFICIAL
DAMN!!!!!!!!!!!!!!!!
That was it. Thanks a million.
Apparently there was a corrupted ,pz3 file set to autoload, deleting that file and the .pmd, now the program starts properly.
Didn't realize (feel like a dummy now!) that settings were stored in that directory.
Thanks again.
Thread: in praise of Carrara hair, GI and SSS and V4 | Forum: Carrara
