12 threads found!
MocPac | 1 | 18 | ||
MocPac | 2 | 23 | ||
Advisories: nudity
MocPac | 14 | 296 | |
MocPac | 9 | 243 | ||
MocPac | 4 | 159 | ||
MocPac | 2 | 51 | ||
MocPac | 11 | 188 | ||
MocPac | 2 | 78 | ||
MocPac | 3 | 60 | ||
MocPac | 2 | 99 | ||
MocPac | 10 | 254 | ||
MocPac | 1 | 64 |
19 comments found!
Thread: Please reset uploads to product 75112 | Forum: MarketPlace Customers
Thread: Poser 7 preview display error | Forum: Poser - OFFICIAL
lol - Sorry. Yeah, I tried using the Main Camera angel and it still does the same thing. Â
Its basically the same thing on all camera angels, but it appears somewhat normal when you zoom in close.
The picture on the right (on the picture that I posted), is taken from the main camera angel. If you look on the right bra strap, you can see the problem is still there, but its not as bad as when you zoom out with the camera.
Quote - > Quote - I'm not sure whats wrong. It does this to all camera angels. Its only normal when IÂ zoom in closely. It started to do this once IÂ reinstalled my poser. IÂ remember fixing this problem before, but I forgot exactly what IÂ did to fix it.
This will be the same using any of the orthographic cameras (Front, Right, Left, Back, Top, Bottom).
Have you tried using the Main camera? It should be fine if you just increase the hither distance.
Yeah. It does this to all camera angels. I have to zoom in close to make sure the clothing is adjusted properly.
Yeah. It helps a little with the teeth but the clothing still suffers from the same problem.
Thread: Victoria 4 Morphs not working properly. | Forum: Poser - OFFICIAL
Quote - *It's V 4.1.
.....*as long as your morphs are compatible - I wonder if what I suggested in the 8:45Â post works to fix it?
BTW I really like your Helena character. Outstanding.
got any more renders of her?
Thanks, loaded everything in the V4.2 model. A few of my characters that are worked on in V4.1 do this, and IÂ was just wondering if there was something locked on it, but IÂ guess not. IÂ just hate loading everything up again - lol, I'm just lazy :(
Well, here is the Helena character image. The hair is different and I'm not sure if I should go back to the previous hair style.Â
NOTE: The photo shows up better if you right-click it and goto "view image."
The character I'm using is Victoria 4.1, along with the Victoria 4.1 Morphs++ set.
For example, if I adjust the nose size parameter dial, the number adjusts but the morph on the character does not. Basically, the character appearance doesn't change, it stays the same.
Thread: Poser 7 Movie Settings. | Forum: Poser - OFFICIAL
Yes its checked, in the original P4 render settings, but it doesn't carry over to the movie settings. The anti alias is grayed out under the movie settings.
Quote - in the "make animation" bit, try setting the format to "image files" that should render a sequence of images.
(I don't actually do animations so I could be talking total rubbish)
Yeah, thats what I did, but the Poser 4 render doesn't ender using anti alias.
I'm just trying to find a way to render all frames one after another. I'm getting tired going back and forth after each render moving the frame bar and then saving it again - lol. It seems like the P4 movie render option works the best but theres no anti alias. I have to see if theres some type of program I can use.
