67 threads found!
MoonRose | 1 | 51 | ||
MoonRose | 5 | 37 | ||
MoonRose | 15 | 526 | ||
MoonRose | 15 | 257 | ||
MoonRose | 2 | 166 | ||
MoonRose | 9 | 666 | ||
MoonRose | 2 | 251 | ||
MoonRose | 5 | 147 | ||
MoonRose | 4 | 123 | ||
MoonRose | 2 | 103 | ||
MoonRose | 4 | 205 | ||
MoonRose | 14 | 595 | ||
MoonRose | 1 | 129 | ||
MoonRose | 5 | 173 | ||
MoonRose | 2 | 318 |
202 comments found!
Thread: Problem with Poser>UVMapper>ZBrush | Forum: Poser - OFFICIAL
Attached Link: http://www.morphworld30.com/
i've never tried morphing a posed character before so i'm not sure why it would give the error when its posed but not when its in the zeroed position... but i have run across that error before... usually with older models... like the p4horse and vicki1... when i brought it into Zbrush (or converted it to bring into Rhino when i still was using that program) it would give that error it gave you... the only solution i found (although i didn't spend THAT much time looking for solutions.. i just wanted the quickest fix i could find lol) was from Traveler's webpage... if you go under Tutor at the top... scroll down to the Rhino tutorials and click on Morphing in Rhino - The Basics, in there you'll find a download of a program called Compose... follow the instructions to run it through Compose and it shouuuuld be ok from then on.. no errors. i say should because as i said i've never exported out a posed model to morph in any program so i'm not 100% sure this will work for you.Thread: "TheGirl" is there... | Forum: Poser - OFFICIAL
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2499841
i think stahlratte's NEA character might be what you're looking for... i have no idea if stahlratte has given out the morph but i'm sure if you ask him/her they might be able to give you the morph (?) *see link*Thread: is there a python that exports all obj's | Forum: Poser - OFFICIAL
yeah.. what SWAMP said :) i'm never good at explaining myself lol i'd be very happy if one could be made :D
Thread: part man part wolf | Forum: Poser - OFFICIAL
just for more options..if you do a search for lemur in the freestuff Lemurtek's Wolfgang comes up... its an older model but still looks good in my opinion
Thread: Pelt Mapping help. Who creates the Maps for Content Paradise? | Forum: Poser - OFFICIAL
its strange that you cant relax an entire body part... after you're done stitching it together you should be able to just select it and relax it. if it collapses in on itself the only thing that i can think of is that there are some points that are connected on opposite sides that shouldn't be, and when you relax its trying to pull itself back to the sides it thinks it should be on. about the stray points.. i can't quite picture what could be going on there so i can't offer any help on that. if you're really stuck you could send me the obj of what you have so far and i can take a look at it.
Attached Link: http://www.righthemisphere.com/support/tutorials/index.htm#DUV
i do the same as Deecey... i go between uvmapper and deep uv. mostly uvmapper to start and the rest in deep uv. a tutorial that i found that helped me get on the right path was at righthemisphere by Colm Jackson from RuntimeDNA. it got me thinking about ways to do it.. the 1st time i did it took me quite a while to figure what goes where. the way i do it... i think about it being cut open from the bottom (for animals... and from the back for humans). when i start in uvmapper i seperate the legs from the body and the feet/paws from the legs. then i have whats left mapped from the top, looking down at it (again if its an animal... i guess it would be from the front if it was human). i bring it into deep uv and follow the steps in colm's tutorial for the body... it taught me alot about how to stitch parts together and relax them. after i have the body done i move on to the legs... i here's where it took me some time to figure out the best way to split up the legs and get them to map right. i had to sketch it out on a piece of paper to finally get what i had to do lol... i'll trrrryyy to explain what i had to do for the legs... i started with a view of them from the front... so i can split them in half.. the "top" side (or the side of the leg/arm that faces out from the body) of the uv map is connected to the body and then relaxed as in the tutorial.. then whats left, the "bottom" is divided again.. because one half of the leg flips up with "1" and the other half flips down with "3".... and so on. after i'm done with the legs its about the same step with the feet/paws/hands.... Colm's tut was what i kept going back to till i got the hang of it. thats about it.... i hope this didn't get too confusing :| its hard without exact pictures of each step. if you have any questions feel free to ask..and i'll be glad to help as best as i can... i should be around more often now.Thread: Unsteady Hands | Forum: Photography
i read in a photography mag that if you dont want to drag a tripod around to steady your pictures... use a length of chain thats long enough to go from the ground to eye level with a screw on one end... then you can put the screw into the bottom of the camera where the tripod would normally screw in. then put one end of the chain under your foot and hold it tight... it should steady your hand some. never tried it.. but it sounds like it should work... and its easier to carry then a tripod or monopod.
Thread: Where can I find this "free" item? | Forum: Poser - OFFICIAL
Attached Link: http://www.keyhole-kreations.com/
i think what you're looking for might be here hope this helpsThread: so did poserstyle finaly go belly-up? | Forum: Poser - OFFICIAL
Attached Link: http://www.poserstyle3d.com
this link works for me... not sure if its the new or old poserstyle though hope this helpsThread: Looking for Jedi Robes | Forum: Poser - OFFICIAL
there's lynnJonathan's robes in freestuff... its for mike2 and vicki2 though.. not the mil3 characters. very nice robes.
Thread: Bear Skin Rug | Forum: Poser - OFFICIAL
