2 threads found!
Oom | 16 | 1023 | ||
Oom | 8 | 190 |
16 comments found!
Thread: Making a face morph for genesis | Forum: Blender
I agree with unnyFies, Thank You millighost!
I would like to use this tool for other figures then Genesis. I guess you would have to tweak the generated dsf some. Any one with any idea on what needs to be looked at?
Cheers! Oom
Thread: Correct settings for DS4 to obj to blender and back? | Forum: Blender
I did exactly like you and jestmart told me, well almost ;)
Instead of exporting a single part of the mesh you export the whole character. No other change in exporting from DS.
(I prefer the the blender scale so I change the scale in the Poser export setting to 2%).
When importing to blender use your old settings but also check the Poly Gropes box.
When you export from blender, use your old settings only also check the Poly Gropes box.
When I import the morph to DS I prefer to use Morph Loader. The free DS4pro comes with both Morph Loader Advanced and Morph Loader pro. Just make certain that the "Swap Y and Z Orientation box" is NOT checked. With the Poser preset it is not checked. With the Morph Loader you can load several morps at once and it gives you better control over the dials.
I hope this will help you, you helped me a lot. :)
Oom
I had the "Swap Y and Z Orientation" box checked in Morph Loader. Now everything works fine.
Thanks again! Oom
Thank you amy_aimei and jestmart!
I just made a quick test on Kururur and it worked perfectly, almost. My morph still rotates and mirrors the entire figure but I think I can sort that out, I used the Blender preset in DS not the Poser.
The morph is there and the dail is working and I am happy.
Cheers! Oom
I have managed to make a morph for a primitive plane :)
The morph also rotated the plane so somthing is still wrong.
I am working on it
Cheers! Oom
Thank you for your answer amy_aimei!
I have tried the settings, but no luck so far I am afraid. What settings should I have in DS4 when I export the obj?
Cheers! Oom
Thread: How do i make a reflection on a mirror? | Forum: DAZ|Studio
Quote - Bearing in mind I know NOTHING about writing scripts, how difficult would it be to create a script out of the above for instant application? Then the reflectivity could be applied with a couple of quick clicks and, yes, I actually AM that lazy! ;-}
The script tool you talk about is DS "Shader Mixer" It has a very easy graphic interface (and plenty of tutorials). You can make some very nice effects easy and it gives you excellent control over surfaces. It can also get extremely complexed with advanced mathematics but that is optional ;)
Shaders can be saved in DS and will apply on (almost) any surface, Materials can also be saved but are tied to specific objects.
Cheers Oom
Thread: Status Update from DAZ | Forum: DAZ|Studio
Quote - > Quote - Don't underestimate your power as a customer. Just say: "No forum No shopping"
And did you apply this same 'logic' to Posers various owners , who did not have an in house forum for years ( and even now have only a shanty town at RDNA )?
Absolutely. If you are frustrated with a businesses, any businesses, show it by closing your wallet.
It is that simple.
Cheers! Oom (a he)
Just wanted to say that I am surprised how easy it is to make morphs in blender. And with the Cycles engine you have live rendering while you work
Thanks again (better spelling this time) Oom
Quote - > Quote - > Quote - It's probably tied to the store but what's up with the forum, inquiring minds would like to know.
The Forum isn't a priority right now - it doesn't bring in revenue. I am sure they will get it together eventually. Just don't hold your breath.
If that's the jist of it, hopefully they can at least look past that and open the board up so we can get back to the business of interacting with each other in a beneficial manner. No Flame intended just curious, I'll wait.
Thread: New dsf to old characters? | Forum: DAZ|Studio
Thread: great idea, now how do I do it | Forum: DAZ|Studio
There is no obvious way to do it with the default camera but I am reasonably sure a camera can be built in shader mixer that can do this. I don't know enough on how to track things to do it, sorry.
