424 threads found!
RedPhantom | 0 | 92 |
(none)
RedPhantom | 0 | 139 |
(none)
RedPhantom | 0 | 176 |
(none)
RedPhantom | 0 | 168 |
(none)
RedPhantom | 0 | 180 |
(none)
RedPhantom | 1 | 87 | ||
RedPhantom | 0 | 181 |
(none)
RedPhantom | 0 | 185 |
(none)
RedPhantom | 0 | 222 |
(none)
RedPhantom | 2 | 139 | ||
RedPhantom | 0 | 280 |
(none)
RedPhantom | 0 | 282 |
(none)
RedPhantom | 0 | 305 |
(none)
RedPhantom | 0 | 272 |
(none)
RedPhantom | 0 | 258 |
(none)
4,626 comments found!
The first is chain break. As you drag a body part, like the hand, it may move a chain of parts, like the forearm, shoulder, collar, chest, etc. If you add one of those to a body part, then it won't move that part. So if you add one to the collar, and drag the hand, it won't move the collar or chest but will the forearm and shoulder.
The second looks like you have bending turned off. You can turn it back on in the properties dial.
Thread: Just out of curiousity... | Forum: Poser - OFFICIAL
2005 here with Poser 6
Thread: No download for newsletter freebie? | Forum: Community Center
May was Nighty for La Femme 2
June is Military Environment (Poser, OBJ & Vue)
The Backyard Living is this month's prime freebie
Thread: Come back! | Forum: Virtual World Dynamics
I removed the image as it contained your personal information. You can repost it without that portion.
Thread: don't understand this.. | Forum: MarketPlace Customers
As others have said, vendors make what they can sell.
LaFemme 2 morphs won't work with L'homme. However, Lafemme's morphs will.
Thread: Writers Forum Carnival Booth | Forum: Writers
Please tell me Dwarf Goulash is made by dwarves, not of them
If you go into your account under my items you can do a search just using FX and it should help you find it. I'd post a
You can find the product here https://www.renderosity.com/marketplace/products/161130/bodyfx-morphs-for-la-femme-2
If you have purchased it, you should see a find in my library button which will take you to the page to download it
If you're looking in your library to download and install that way, make sure you're on the purchases tab rather than the search tab.
Thread: 3-part view, can't locate ground... | Forum: New Poser Users Help
yeah, the bed is all wompy jawed. Select the bed. Then go to edit>restore>object and it should fix it for you.
Thread: Gallery Block Button | Forum: Community Center
You can find them in the gallery by the thumbnail of the images
Thread: Texture Loading with Firefly | Forum: Poser 13
I just checked. Poser 11 loaded the textures for the second render in a row.
Thread: How to use Wave to create ripples | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
that looks good
much better
You can also get some interesting effects by adding more than one wave to an object
Here's my setup for ripples. Move the wave off to one side to not show the full ring. Use the morphs to affect how the ripples look. You can see which ones I used. You do need to make sure you have enough polygons. It doesn't seem like subdivision will help with that
Thread: Challenge Arena Forum Carnival Booth | Forum: Challenge Arena
I think this might be a reason to switch to margarine.
Thread: wth are these things | Forum: New Poser Users Help
