35 threads found!
TIMMYLYNN | 0 | 156 |
(none)
TIMMYLYNN | 0 | 1029 |
(none)
TIMMYLYNN | 13 | 315 | ||
TIMMYLYNN | 6 | 138 | ||
TIMMYLYNN | 17 | 270 | ||
TIMMYLYNN | 2 | 76 | ||
TIMMYLYNN | 7 | 145 | ||
TIMMYLYNN | 2 | 120 | ||
TIMMYLYNN | 1 | 44 | ||
TIMMYLYNN | 16 | 558 | ||
TIMMYLYNN | 5 | 312 | ||
TIMMYLYNN | 13 | 150 | ||
TIMMYLYNN | 6 | 102 | ||
TIMMYLYNN | 1 | 31 |
64 comments found!
Yes I would have like to have done more with it but only had a limited time frame to get it on and then I ran into alot of problems with the mov/windows movie maker problem. I ended up having to save each frame out of image ready as a bmp to get it edited in windows movie maker. I was going to let them know I used their moviemaker but man after that day I was so frustrated...this is hilarious, I wished I had a mac. I have never used one but everyone tells me they are better. I have some other animations on that site where I moved the letters some. I'm still experimenting with basic animation and really am leaning towards doing character animation for fun of course. Thanks for taking a look and all your info. :)
Thread: avi mov ???? | Forum: Animation
Thanks guys. I have learned alot just from you guys input. After some investigating, I used Modo to render my original animation and as I stated plays beautifully on the qt player so I'm not sure about the compression because in modo you have option to make mov or image sequence. That was another question I have. Is it best to render out a image sequence and then turn that into an animation? If show is BMP the best format to render an image sequence in? One of my programs only has the option to render out an image sequence. And the site I uploaded this particular animation to does change to flash from what I can tell. So the compression done by the program to get in mov and then the compression of the web site to flash really degraded the animation. Here is a link for you to have a look to see. Hope this info might be useful to others also. Thanks again.
http://www.brickfish.com/Pages/VideosSeries/VideoView.aspx?qsi=16428044
Thanks you guys!!! That's some awesome very useful info. Many thanks!!!
I am going to do some other research on my own at wikepedia but as far as when you finally get a good clip and you want to broadcast it on the internet. The web site I post to when playing the animation it jerks even worse and doesn't play as smooth. Does this have anything to do with the compression/codec?
kind regards
so with apple its compression and with windows its codec? The codec thing is something I need help with also. For instance which codec is best for a poser animation? Do you have to purchase decent codecs. I've used some of the selections before just as a test and neither of the players have been able to playback file?
Thread: Poser Pro prop question??? | Forum: Poser - OFFICIAL
That was the answer raven. Thanks so much to both of you and have a great weekend guys!!!
peace and love
thanks guys for the replies. sorry my explanation was not clear. Yes I am trying to remove the obj from the pp2 file so I will try the plug in in a bit. I know how to delete a prop. Sorry for the confusion. I will try to plugin and see if that works. Are you guys using poser pro?
thanks
I'll let you know how it goes.
peace and love
Thread: problem with v6 infinite on vista 64 help please | Forum: Vue
Happy Ending!!! Reinstall worked BUT eon doesn't seem to like for you to place your documents folder on an external drive...let it install on my computers harddrive and now all the save buttons work, thank goodness and here's to dealing with a new operating system!!!
Thanks for your help you two!!! I really appreciate it!!!
peace and love
im gonna try that today after some other things... I found a link for improved performance...turning off a bunch of this stuff like sidebar etc...im gonna do that and check the folders again b4 the re install. if re install doesn't work ill be back at eon. I appreciate your input. will post solution when I find it...if i do...lol
peace and love
i just tried to save an animation and the browse button on the render options panel does absolutely nothing. I'm ready to throw it...lol
http://www.vistax64.com/vista-general/75750-vista-does-not-allow-me-save-c-drive.htmlÂ
well I have spent about an hour making sure i am owner and full control. but it still will not save a render to screen. still no dialogue box opens for that...it is really strange because it opens for scene object...etc...just not for picture. havent tried animation yet...but i found a very disturbing thread. Please see the link above.Â
i agree about uac...turned it off as soon as I turned on computer almost. The folder thingie may be the problem.   I found something about powerpoint issues with saving for vista on the microsoft website last nite. It was talking about folders. Can you give me more detailed instructions on how to check that? It is very weird all other programs are working and if i try to save scene it opens the save dialogue and it pointing to the documents/scenes folder automatically....but if i hit any of the other disk save buttons.....nothing....try to export picture and nothing....so maybe it is the folder thing. I will investigate more and if you can give more detail on how to check that would be great also....
peace and love
also during my investigation i found that if you select the launch app now on the initial install it auto sets it to elevated...(run as administrator)...
yep i'm the admistrator and i did right click and select the run as administrator with the little shield beside it also....
