19 threads found!
Vaskania | 4 | 191 | ||
Vaskania | 1 | 247 | ||
Vaskania | 6 | 3291 | ||
Vaskania | 5 | 114 | ||
Vaskania | 3 | 65 | ||
Vaskania | 4 | 200 | ||
Vaskania | 3 | 103 | ||
Vaskania | 4 | 108 | ||
Vaskania | 3 | 64 | ||
Vaskania | 3 | 1165 | ||
Vaskania | 29 | 434 | ||
Vaskania | 9 | 546 | ||
Vaskania | 1 | 47 | ||
Vaskania | 6 | 91 | ||
Vaskania | 2 | 34 |
329 comments found!
Chris_T over at sharecg still has a few items- gas masks and fetish wear. https://sharecg.com/pf/full_uploads.php?pf_user_name=chris_t
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
Thread: Why do texture map PNGs take on a blue tint ? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
@3dcheapskate There is a possibility that it's a game ready asset as some engines use the RGBA channels for supplementary maps, like normals. Open the original PNG in an image editor and look at the separate channels. If there are normal in the alpha slot, that would explain it looking normal when saved as jpg as jpg doesn't retain the alpha channel iirc.
-----sig-----
Thread: Python editor support: New version | Forum: Poser Python Scripting
Thank you for making this. As a visual studio/vscode user, flubbing around w/ poser's internal shell was driving me bonkers.
Have a decent flow now. Code creation on my wsl side w/ Netherworks' Scripts Auto Launch pane open and just hit "launch now" to test the script. /happy
-----sig-----
Thread: Changing "hidden" hotkeys? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Alright, thanks. I'll take a dive into poser's python reference and see what I can find.
-----sig-----
Thread: locking down shapes | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Embedding morphs in a prop I never bothered learning since the only real creation stuff I did in Poser was for Dawn, which used pmd morphs. For those I use D3D's Binary Morph Editor.
Looks like it might be as simple as just loading your prop, getting the morphs into it, setting your dials and whatnot, then saving it back out and just uncheck "binary morph targets". https://www.renderosity.com/rr/mod/forumpro/?thread_id=2812085
-----sig-----
So, the plugs in the pack don't deform with the figure. They're smart parented to the figure's head, but also include morphs of their own to account for translation issues. If you morph V4's head, the plugs stay in place and require manual tweaking for figures that aren't included in the props' morphs. Ignore the lack of transparency. I don't have Advanced Shaders installed to apply the maps.
-----sig-----
I think there's a misunderstanding somewhere. What you call "ear dobbs" I'm assuming you mean plugs. Round discs that go into stretched ears, usually tapered or grooved w/ rubber rings to prevent them from falling out.
I'll take a look at metal madness and see how they pulled it off.
-----sig-----
Ok, I've realized that the "mode" shortcuts in the hidden shortcuts are named something different in the key preferences, ie Pose Mode (hidden) -> Select Actor (key prefs).
What I can't find is where to remap XY Translate, Z Translate, Pivot, and Axis Constraint. Also, if there's a way to reverse zoom natively. Right now I use Netherworks' Camera Panel Plus to do it.
-----sig-----
I'm assuming you're talking about plugs. If you have Metal Madness over at Daz, it comes with V4/Poser compatible tunnels, which are basically hollow plugs, that you could dissect and see how they work. If not, let me know and I can open it up and take a look.
-----sig-----
Thread: Update Car | Forum: DAZ|Studio
If you're dead set against Blender, Maya Indie is less than $300 USD/year.
-----sig-----
Thread: Texturing | Forum: Freestuff
https://cc0textures.com/
All public domain, and there are SBSAR materials there too.
-----sig-----
Thread: anybody use HDRIs from hdri-skys.com? | Forum: Poser - OFFICIAL
hborre posted at 2:00AM Sat, 19 December 2020 - #4407936
Unfortunately, HDRShop is no longer available, it was an excellent app to over-/under-expose an image and then combined to generate an HDRI. It's a hack but it's a great way to take a hi-res jpeg and use the image and light data in Poser.
You can technically do it in any app that supports setting exposure values. Just need something to merge them together. I don't personally create HDRs out of single exposure images (I prefer tripod+DSLR and creating the ev steps in-camera), but I know Affinity Photo can do both. Use the develop persona to create something like -4, -2, 0, 2, 4 out of the original (which would be the 0), then use file > hdr merge and import them all there.
-----sig-----
Thread: Where to buy the rabbit from the hameleon promos? | Forum: DAZ|Studio
It's Dead Bunny by Styxx in the freestuff. https://www.renderosity.com/rr/mod/freestuff/dead-bunny-character/57190
-----sig-----
EClark1894 posted at 3:31PM Fri, 18 December 2020 - #4407889
All HDR sky maps are free in 2048×1024 size.
Which is garbage quality if you intend on using the HDRI to get a matching ground plane as well. It'd be too blurry for anything close to the subject. https://www.youtube.com/watch?v=RsAUfQlZH_w
-----sig-----
Try HDRI Haven. All free. So far the largest resolution I've seen on there was 20k which was between 500-600mb.
-----sig-----
Thread: Anything for Victoria 3 still out there? | Forum: Poser - OFFICIAL
