2 threads found!
Vigne33 | 11 | 325 | ||
Vigne33 | 15 | 283 |
16 comments found!
Thanks a lot to have picked my picture Chess Party At Manhattan! This is nice to find still nice pictures with Poser regarding the present force of daz studio!
Thread: Completely beginner in Poser 9 | Forum: Poser - OFFICIAL
Hi hborre, many thanks for your help, by spinning the dial to make angry in the parameters window, the angry face appeared; wonderful, it is magic!!!!. I have also learnt from you that Victoria is Vicky among the artists, thanks. I do not have to look for this new character!!!lolll
Lastly, last week, I got a good tutorial from DAZ 3D for installing the DAZ 3D contents in Poser. I join here this tutorial, it can be useful for new Poser-DAZ 3D beginners!!! The trick was to install all DAZ 3D contents through DAZ 3D and not through Poser in the installation application and specify correctly the target folder, ie. Program Files/Smiyh Micro/ Poser 9. So the trick of the dummy file was avoided.
I have installed correctly Victoria 4.2 and Victoria 4.2 Mprphs++ purchased from DOZ 3D. I loaded Victoria 4.2 figure, by default she has hairs and wears a swimmsuit. I wanted a completely nude figure, I could get a nude figure by selecting !all mapless in MATerial sample-Res, is it allright?
Then for example, I wanted to modify her head with the "angry" morphs, I clicked on selected angry and nothing happens after loading. Is it normal? I do not know how to use Victoria 4.2 with morphs++. Is there somewhere a basic tutorial for Victoria and V4 Morphs++?
Thanks
Thread: Start in Poser 9 directly with the new Victoria weight mapped character | Forum: Poser - OFFICIAL
Quote - Yes. The pwerloader file is not necessary for Poser.
Yes I got well from you but I tested the application to see whether this one worked...
The attached file before modification
Do I make well?
I created a text file (empty, ie. the dummy file?) denominated dzInstall.ini, then I put this file in the last folder of the path indicated in the error window ie. DOZ .
My attached files 1/Â before the modification
2/ after the modification,
Is it allright?
Robert
Â
I have started the application ps_pe069_Victoria.exe. After having agreed and selected Poser (all files) application, unfortunately I had an error message from Windows as shown in attached file Error reading INI file. What it means, is my loaded Victoria file from DOZ3D corrupted? or is there something else?
Â
My computer : hp Pavilion dv9700 notebook PC , Windows Vista SP2, 32 bits
Thanks for your help,
Robert
PS : I have just made a message to DOZ3D support service.
Â
Quote - You must have V4 already installed into your runtime first, the installers are not needed at all. Now the WM zip content can be placed in any runtime of your choice, as long as all the zipped content are kept together.
For Poser, only the V4 Poser Installer is necessary; one belongs exclusively for DAZStudio (it has DS in the title) and the other is the powerloader which is also exclusive to DAZStudio. V4 does not necessarily need to be in the main Poser runtime, but if you purchase additional morph packages in the future, they must be installed into the same place.
What is the V4 Poser installer, where is it? I have to click on the ps_pe069_Victoria.exe file? and then there will be questions about installation of Victoria in Poser 9?
Thank you for your patience,
Robert
Hi I could do quite quickly the clothing by the choice of conformed hairs and the conform function for the clothes and the result is joined below.
One question the image is exported easily but are they different resolutions of pictures possible and without the Front camera indication on the left top corner? It seems that there is no choice...I can change the upper background color but not the lower one, why? It seems to be locked, with the figure.
Thread: How to transfer weight map from character to clothing? | Forum: Poser - OFFICIAL
Attached Link: http://youtu.be/2t3BUBV22u8
Hi Can this video help you for your question? I have just purchased Poser 9, so I would be interested to know what is the utility of weight mapping in Poser 9 version...I am completely beginner in Rendering painting.Â
Hi willyb53,
Thanks for your help. My problem was that I was unable to open the Library Pallette. I have resolved my problem in opening the library through the small icon present top right of the room window (circles icon).
And for the Flash, I reinstall the last version of Medie Flash Player from Adobe through the window of Poser 9 revealed by clicking on Library, before I found the solution to open the Poser 9 Library Palette.
In have now the Library palette and I can go through the Poser 9 Library folders.
Thanks a lot for your friendly help.
Robert
Thread: **Most Asked Poser Questions** | Forum: Poser - OFFICIAL
I got your explanations.
I could load figures from Poser 9 library. I loaded Kate 2 figure from Poser 9 library, a nice girl. But now my problem, I have the first skeletton Andy 2 already present when I opened Poser 9 plus my Figure Kate 2. What I have to do, work with the skeletton which have the selected pose Run10 of Kate2 and the figure? I am confused....Then I stop for to day, I need rest...My brain is rendering as a beginner of Renderosity...
Robert
Â
Â
Hi DarrenUK,
Thanks a lot, I clicked on the icon and it appeared 2 folders 1 with Poser 9 and then all sub folders with vehicle, people, etc and a second one Download which is empty. I got that all these folders are the library given by Poser 9, Wonderfulllll.
On the top right of the new windows there is an folder icon with a guy walking and entitled add library, what do I do? I left click for adding library?
Thank you for your patience I do not want to do wrong...
Robert
Hi DarrenUK,
Robert
Thread: Poser Staff Picks: March 11 - 17 | Forum: Poser - OFFICIAL
