4 threads found!
alexkuzelicki | 6 | 177 | ||
alexkuzelicki | 3 | 71 | ||
alexkuzelicki | 3 | 108 | ||
alexkuzelicki | 3 | 94 |
6 comments found!
Thread: Swap Left & Right Question? | Forum: Poser - OFFICIAL
Thanks for the advice. Should have known running a python script would be that simple. I have much to learn. Thanks for your help. ALEX
Hi Pakled, Semidieu suggested this website with Python scipts. Apparently, SwapTotal does the job. http://ockhamsbungalow.com/Python/ Now, if only I knew how to use Python scripts. Ahh, so much to learn. ALEX
Thread: Copying Blocks of Keyframes? | Forum: Poser - OFFICIAL
Thanks kindly for the reply. How do I save an animated pose? A quick explanation would be great. Also, I've discovered another workaround for copying blocks of keyframes: use the Retime Animation tool. Instead of using it to retime animation though, I just keep the same timing and slot it in where needed. So far, this seems to be the most reliable way for me but I'm keen to try out the Animated Pose method. Much appreciated, ALEX
Thread: Alpha Channel Changing? | Forum: Poser - OFFICIAL
Thanks for the help. Much appreciated. I've since found that if I change the resolution BUT keep the aspect ratio, the Alpha Channel remain Pre-Multiplied. Will definitely export as Image Sequences from now on, where fine quality is an issue. Thanks again. ALEX
Thread: Background Video/Picture No Show??? | Forum: Poser - OFFICIAL
Hi, Thanks for your replies. Tech support also suggested the Display > Preview Drawing > SreeD Software option. And it works! Happy now. Your advice (and time) is much appreciated. Regards, ALEX hybrid@bigpond.net.au
