10 threads found!
c567591 | 1 | 21 | ||
c567591 | 1 | 17 | ||
c567591 | 6 | 162 | ||
c567591 | 1 | 24 | ||
c567591 | 8 | 211 | ||
c567591 | 3 | 79 | ||
c567591 | 0 | 29 |
(none)
c567591 | 3 | 69 | ||
c567591 | 1 | 51 | ||
c567591 | 5 | 107 |
15 comments found!
That link is dead, can you re-provide it?Installing/uninstalling assets is very convenient with Daz Install Manager. But Renderosity does not support DIM format. I found, a long time ago, this little tool written in python. It will allow you to convert the Renderosity archive into a DIM archive that you can install/uninstall more easily ;) If the author recognizes himself, I hope he won't mind sharing this very useful tool. Run the program without parameters to know the syntax. Written in python, it can be used under Linux/Mac/Windows
https://workupload.com/file/UubceHwytvR
Thread: SR4 auto-gamma setting | Forum: Poser - OFFICIAL
I will try reinstalling 2014 Game Dev and try Snarly's script and see if it helps in QM perhaps this weekend.
@bhoins...
Noone is questioning that.
The problem comes in now that Poser or QueueManager auto correct things where they did not before.
If there is an image plugged into diffuse AND one of the other channels now it gets auto corrected to 1.0 for us where it did not change before. Thats the problem... so a scene that worked ok before this update gets thrashed and requires a lot of work to fix it which then ultimately gets ignored next reload.
If there was an option to use it or not i think most of us wouldn't have an issue. Because it happens automatically is the real problem.
Many products do this wrong and thus many scenes get changed dramatically.
Quote - Â Â Â Â So it may be awhile before I can get the network function of the script tested.
Â
Have you had a chance to test the network queueing?
Thread: Missing Manuals on Material Room | Forum: Poser - OFFICIAL
Thread: Space Pilot 3D Mouse | Forum: Poser - OFFICIAL
ok, thanks for the help all.
I restarted from scratch and deleted the Space Pilot config from the AppData folder and started over.
When I did this, the Button1 worked as indicated.
Dunno what was different, but it worked so its all good.
I tried that button1 thing and that didn't help.
Apparently its not quite the same function that it is in the Space Navigator :(
I suppose the drivers could have changed or something.
Thread: Poser Shadow Prevention | Forum: Poser - OFFICIAL
No, you have it backward nekkidchicken...
I have shadows off already cast by the backdrop. I don't want the characters shadows showing on the backdrop itself... looks odd when Vicki's shadows are as tall as mountains... :)
I think Miss Nancy may be on right track there, will have to try that.
Thread: Make a simple UI | Forum: Poser Technical
I have Poser 7.
If I used pzrXml, would the resulting Python script be distributable or would they need pzrXml too?
I'd like to share this once I'm done, unless this idea of mine just sux and isn't worth sharing. :biggrin:
Thread: Wanted: Someone to help me model some armor | Forum: 3D Modeling
A functional suit of plate and chain mail. No, not a sexy chain bikini or sexually realted armor. It is a functional armor, yet still curvy and attractive. Plate type armor inspired by various fantasy artists, so not a historically accurate piece, but still would provide a reasonable amount of protection. I have a pencil sketch/drawing that I can share, once someone is suitably inteerested.
Thread: V3 with working dials | Forum: Poser Technical
I did that, and I have the dials, but they don't do anything until I reinject the appropriate morphs. Usually the "All expressions", when I do that, then they work.
Thread: Getting in touch with your Inner Pirate | Forum: The MarketPlace Wishing Well
Thread: How do I install Renderosity Content in Daz Studio in Win 10? | Forum: DAZ|Studio
