4 threads found!
chupacabra555 | 10 | 503 | ||
chupacabra555 | 2 | 86 | ||
chupacabra555 | 9 | 1211 | ||
chupacabra555 | 7 | 218 |
6 comments found!
Question: Has the policy chanced recently?
I've made a few purchases recently, and I didn't see my points go up at all.
Checking the Rewards page, this is what it says (see below):
It seems like the "5 points per $1 spent" is gone.
So, is this now the new policy (unless you are a Prime member you no longer get points for purchases)?
The chart below lists what you can do to earn points and the number of points you get for each action.
Action | Points |
Contest Entry Approved | 20 |
Contest Vote | 10 |
Freestuff Item Approved | 20 |
Gallery Image (Non-Vendor) | 10 |
Gallery Image (Vendor) | 15 |
Marketplace Purchase (Prime)
Prime members only. |
7 per dollar spent |
Thread: Newbie Question on AniMate for Poser | Forum: Poser Technical
First off, "Thanks" again for all the replies ^_^
@HartyBart: I had intended on using the program for Victoria 4, and that is why I thought it was for Poser (the product I mentioned was made to animate V4, so I just assumed it was for Poser).
I haven't tried any animations with Daz yet (I can barely render a good Iray image after hours, have no idea if my poor system can handle rendering many images in sequence for animations).
@Y-Phil: I'll check out the link. Can it be used for either Poser or Daz?
@Bwldrd: I do have the aniBlock Importer for Poser , another reason I thought it was for Poser. If the AniMate program isn't for poser though, I have no idea how to use this product then. I'll try to find some kind of tutorial, though.
Thread: Problem with Gift Certificate Purchase | Forum: MarketPlace Customers
Thanks for the help :) For some reason, it wasn't showing the gift certificate until I went to pay.
Thread: Problem in Poser 11 with Victoria 4 following Clothing Morphs | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Sorry for the late reply here, but a big "Thanks" to all those who responded ^_^
I'll try the suggestions. If it doesn't work, I can always fire up my copy of Poser 9 (loose some flexibility, but nearly as good).
Thread: REQ: 'Klingon' forehead, weapons, costume props | Forum: Poser - OFFICIAL
Once again, thanks to all the replies.
When the work is done (and with the artists permission), I may post the finished version here. I will also post it to my blog, but there are images there that are definatelly inappropriate for this forum. :-)
Thanks to the mods for moving the subject, and for the reply.
Just to provide a little more detail for the hell of it, a online friend of mine is trying to reproduce, in poser form, a commissioned 2d art image I had done a while back (pg 13 image, so I think it is still appropriate to post the link here [and yes, they are huge, aren't they? :) ).
Thread: Frequent Buyer Program | Forum: Suggestion Box
