10 threads found!
cjd | 3 | 269 | ||
cjd | 2 | 75 | ||
cjd | 5 | 179 | ||
cjd | 7 | 171 | ||
cjd | 0 | 20 |
(none)
cjd | 0 | 28 |
(none)
cjd | 5 | 132 | ||
cjd | 11 | 214 | ||
cjd | 1 | 73 | ||
cjd | 5 | 202 |
217 comments found!
CloudCompare has a tool to unroll a cylinder. Some functions in Cloud Compare will only work on point clouds, I don't recall if this one is limited to point clouds only or if it will work on a mesh
Thread: exiles | Forum: Carrara
Sueposer posted at 1:30PM Fri, 25 October 2019 - #4368214
Yes, the other place has their plans (nothing wrong with that), but they think they have to maintain all this big secrecy and disconnect from the rest of the community. "Corporate think" has them in thrall.
They are shooting themselves in the foot and it's not like there hasn't been enough communication/feedback from the community to make them aware of that. Having seen this in many small organizations, its not the company as a whole, its an individual with no accountability in a very high place.
Thread: Creating 3d objects from 2d graphics. | Forum: 3D Modeling
Casinoonline posted at 6:25PM Thu, 15 August 2019 - #4359255
Is it possible to automatically combine 3 drawing of a part into a single 3D object in autocad?
Also, could someone please let me know what the abbreviations TYP, TAP, and NC mean?
I am new to AutoCAD and I do not understand half of this drawing below. Thanks all.
Did you attach the drawing? TYP (abbreviation for typical) meaning the same detail or spec occurs in several places. TAP means using a tool to create threads, usually followed by a thread spec. NC could refer to numerical control, as in a computer controlled cutting machine
Thread: Unknown Point Cloud File help needed | Forum: 3D Modeling
The system that etches the 3D points in the glass may be using a rotating mirror so these may be spherical coordinates. (Some values may be angles rather than distances). You might post this on the CloudCompare forum. Daniel is the developer and checks in there all the time so you could get a direction to go in fairly quickly.
Thread: usb 3.1 Hard drive cloners??!! anyone tried these? | Forum: Carrara
Backing up to disk images can work as well. High capacity drives like 4 or 5Tb are pretty economical and can store multiple images.
Thread: Which Software for 3D Modelling from Point Cloud? | Forum: 3D Modeling
So you want to extract BIM models from scans as well as surface (triangulate) the point clouds?
I contract for a 3D scanning company we use multiple applications depending on the job requirements ... Cyclone, Recap, Pix4D, Photoscan and Geomagic. Unfortunately, there is no one size fits all solution.
Thread: Modeling plants for a scene : Which technique/tools to use ? | Forum: 3D Modeling
I think that leaves would be very problematic when 3d scanned or when using photogrammetry. Aside from the cleanup that Luxxeon mentioned, these techniques do not produce double sided polygons, so the polygons would have to be converted to double sided. (I am assuming one would not want to represent a leaf as an object having thickness for obvious reasons.) And, one would also have to decide how best to map the leaves from the texture captured in the scan, considering that leaves are usually translucent (Scanning/Photogrammetry techniques do not capture translucency).
Thread: who carrara artists come here but not the 'other' forum? | Forum: Carrara
MistyLaraPrincess posted at 7:04AM Wed, 16 August 2017 - #4312209
the notes of g3 carrara was zapped.
some of that information might have been helpful to the carrara developer team at rhymes with haz
In addition to promoting their own products, it seems they are promoting ignorance as well.
Just wanted to add that password managers that run on a phone and store the info online can be less secure.
headwax. posted at 7:38PM Sat, 12 August 2017 - #4311853
I come to both. I don't post much here because I can never remember my password- so a simple post takes ten minutes before I am even logged in!
There's an app for that! Look for one that's encrypted as well as password protected and works on your phone AND computer. Or, you can use use a text file (ie.notepad) or spreadsheet and use .ZIP with encryption.
Thread: not looking to replace my Carrara any time soon | Forum: Carrara
Hexagon as well ... although other modelers have more functionality now, especially when it comes to texturing/UV mapping. Unless I have a model with millions of polys/triangles I'd still prefer to use Hexagon. Like Wendy, I think going to Blender is probably the best option without spending a lot of $$$.
I have been looking at Ultimate Unwrap 3D. I'm not clear yet, if it offers any advantage over Blender's UV mapping ... have to go back to look at Blender's mapping functions.
Thread: Retopology Tools | Forum: 3D Modeling
I'm curious why the interface has not got more attention. For a 3D app it has the least functional interface I have ever used. Even Blender is better.
To be useful to all, high frequency detail would have to be addressed. Perhaps there is no universal solution.
LuxXeon posted at 12:18AM Wed, 21 June 2017 - #4307950
Mesh Fusion is now an integrated module in the latest releases of Modo. It was originally a separate plugin, but no longer. I'm not a huge fan of Modo, so I don't know how deeply integrated the features are, but Mesh Fusion is actually a direct spinoff of the GroBoto technology. Darrel Anderson is actually working for The Foundry, and was one of the original designers of the Mesh Fusion product. Here's an article from 2016 about his work with The Foundry.
https://www.thefoundry.co.uk/blog/meshfusion-from-early-beginnings-to-future-thoughts
Ah, the Foundy, not Luxology.
When I first saw MeshFusion about 2 years ago my first thought was given enough time, it looked like it had the potential to make the whole nurbs vs polys issues go away.
Thread: Ideas on How to Unroll a Cylinder. | Forum: Blender
