8 threads found!
david_macrae | 6 | 332 | ||
david_macrae | 2 | 60 | ||
david_macrae | 13 | 1582 | ||
david_macrae | 2 | 375 | ||
david_macrae | 9 | 1267 | ||
david_macrae | 7 | 358 | ||
david_macrae | 2 | 75 | ||
david_macrae | 1 | 44 |
72 comments found!
Thread: 13.1 for macos does not have the option to render an image sequence | Forum: Poser 13
Sometimes i feel really dumb all I had to do was press render images and as you said it output the images to desired folder location. then the second step is to encode images which will deposit desired encode in same folder.Â
Thread: Does Poser run in Mac OS High Sierra? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
High Sierra installs APFS case Insensitive by default which means yes it runs poser and most all other apps. I upgraded and have no problems. Also PS CS6 works as do all my 32 bit apps like hexagon.
Thread: Twice as long to search | Forum: Community Center
Thread: Small update to my FX pedals | Forum: Poser - OFFICIAL
awesome pedals. They look really good. Any chance of getting a wah or expression pedal or cables. :-)
Thread: Japanese animation studio releases its production software | Forum: Community Center
Interesting. I knew they used maya for their modeling and animation but their proprietary plugin seems to incorporate 3delight renderer for npr rendering.
Thread: need help getting talk designer to work for M4 | Forum: Animation
Sorry for late response I never come to this part of the forum but here are viseme xml for m4:
https://drive.google.com/open?id=0BxnCBXSb9V4jemhteVVzSEcxNVU
and v4:
https://drive.google.com/open?id=0BxnCBXSb9V4jdUVNZ1B4RUJXd2c
Thread: Zoom (command) stopped working | Forum: Poser - OFFICIAL
Try deleting your poser preferences at ~/Library/Application Support/Poser Pro/11/Poser Prefs
Or whatever version you have. You might want to copy it somewhere else first.
also ... with camera selected cmd+left mouse button drag to zoom in and out. (If an actor is selected the action will be performed on that actor ie. character, body part, prop)
also ... alt+left mouse button drag - to rotate camera (no matter what actor is selected)
also ... space bar+left mouse drag - to pan camera (no matter what actor is selected)
I had problems when I installed logitech mouse software on my macbook pro. it switched zoom and up down. (It still did all the same scroll just with different hot keys. I did not like it) I ended up uninstalling the software and just using the mouse without it on my mac. now I still use the logitech mouse with native os x mouse controller set to natural scroll in system preferences. Also I assume you have scroll to zoom checked in poser preferences interface tab.
scroll wheel zooms in and out. shift+scroll moves left right. cmd+scroll moves up down. alt+scroll rotates up and down. alt+shift+scroll rotates left and right.
Thread: What's up with the site here? | Forum: Community Center
well heck I went to breakfast and came back and it appears that it is now working socket io is loading correct from cdn.orig-socket.io thats good all working now.
The problem is from Amazon I do not know who is at fault socket.io (I think the server serving up socket.io js) or aws but in is not your server just your reference to the socket.io javascript which could be changed to the above library. Sorry if I spam too much but I was interested in getting to the bottom of this. ;-)
Thread: Poser 12 and Sonoma 14.0 | Forum: Poser - OFFICIAL
