149 threads found!
ddaydreams | 2 | 162 | ||
ddaydreams | 9 | 6763 | ||
ddaydreams | 6 | 387 | ||
ddaydreams | 2 | 411 | ||
ddaydreams | 2 | 646 | ||
ddaydreams | 7 | 784 | ||
ddaydreams | 5 | 390 | ||
ddaydreams | 0 | 208 |
(none)
ddaydreams | 2 | 384 | ||
ddaydreams | 18 | 653 | ||
ddaydreams | 15 | 858 | ||
ddaydreams | 3 | 208 | ||
ddaydreams | 5 | 2615 | ||
ddaydreams | 30 | 3845 | ||
ddaydreams | 5 | 3106 |
783 comments found!
Here's what I find disturbing. it's the last paragraph at end of section 2.7 of the maintenance plan agreement.
"By no means whatsoever does e-on software guarantee that it will make available any update, upgrade, fix or revision during the term of your maintenance plan. You hereby acknowledge and agree that you may not receive any update, upgrade, revision or fix, or any form of support whatsoever during the term of your Maintenance Plan."
So this seems to me to be saying it's possible that that you will get nothing for your money. This seems to be what's happening now. Hard to say since there's no news from e-on and questions about upcoming new versions go unanswered.
Frank Hawkins/Owner/DigitalDaydreams
Frank Lee Hawkins Eastern Sierra Gallery Store
My U.S.A eBay Graphics Software Store~~ My International eBay Graphics Software Store
Thread: Any New Vue Infinite on the Horizon? | Forum: Vue
Quote "According to a known employee on the E-on forums yes there is, and they -hope- to get it out before midsummer" Got a link to the midsummer statement?
Thread: Select Render Area malfunction | Forum: Vue
I now have a workaround that works for me. Start render area at TOP LEFT then drag to the right, then down and release.
Thread: Largest resource of free Bryce textures? | Forum: Bryce
Thanks, I like premade ones as a starting point, so that when I see one I like that's close to looking like what I had in mind. I can tweak it and zero in on a mor exact look. Then do the Arial view you mentioned rendered at what ever size I need.
"Also it really depends on what you mean by "Bryce textures" Do you mean actual things like "rocks.brt" or just an image that you can use as a texture inside Bryce?"
I meant procedural textures aka .mat files
Thread: Which versions of Vue do you use? | Forum: Vue
I'm using V10 C, V11C and V2014C
Thread: Create Metacloud from an object? | Forum: Vue
Funny you should mention helios. I was just checking that out last night. Not sure if it will use metaclouds the way I need but I'll look further into that. Especily if the pending $99.00 USD version will do it.
That's unfortunate, metaclouds have been around for many years now. I 'm surprized that this need has not been addressed and solved. Oh well at least I can still shape them into prett much any shape maunually given enough time. Keeps the Work in Art WORK
Thank for the Script idea.
I wonder if there's a way I could populate a mesh object of the desired shape with metacloud spheres using an eco system. If not I think I'll ask that as a feature request. That would be useful to me.
Thread: Roll Call | Forum: Bryce
Still lurking here once in a while.
No Bryce art to post right now but still doing art, with plans to do much more.
These days I do Vue, Photoshop, Filterforge and will be doing more Vector work, Learning Adobe Illustrator and still doing some landscape photography.
Thread: Stuck in always getting ready to make art mode. | Forum: Vue
Thanks
Frank
As it turns out, this was a correct assumtion that a Style would arise from doing art projects rather than trying to think up a style. These were recent projects I did that began to develope into my own style.
So for me the Project based learning and doing art was the way to go.
Here are a few of my recent works.
Thread: hope someone can help | Forum: Photoshop
If cs6 does not work even in 32 bit or compatability mode another solution might be to get an older cheap 32 bit photoshop elements and run your 32 bit xeno filter on that.
Why not run the 32 bit version xeno in 32 bit photoshop on your 64 bit system.
Since photoshop can install and run in 32 and 64.
I always install the 32 bit of photoshop version to run old filters.
And I install the 64 bit Photoshop for all else .
Right now I'm running Xenoflex 2 on 32 bit photoshop CS5.1
I'm assumimg that would work for CS6 also.
