9 threads found!
deedub | 5 | 178 | ||
deedub | 11 | 132 | ||
deedub | 10 | 257 | ||
deedub | 11 | 254 | ||
deedub | 6 | 159 | ||
deedub | 5 | 224 | ||
deedub | 4 | 138 | ||
deedub | 24 | 569 | ||
deedub | 5 | 154 |
37 comments found!
Thread: brushed metal shader | Forum: Carrara
Thread: Poser 4 on the Mac | Forum: Poser - OFFICIAL
Attached Link: http://www.soft-rabbit.de/
Thanks a great deal guys: yes, it is soft-rabbit, and off I go to convert a few hundred cr2's & rsr's! YAY! deedubThread: This just in... ! | Forum: Carrara
DUH! Would you guys mind posting a reminder on how to make seamless textures using the 'offset' feature in Photoshop? I knew how to do it and, dang, I forgot how. deedub
Thread: Transposer test animation | Forum: Carrara
May I humbly suggest that your fine work would benefit from a little more swivel at the pelvis. I've studied the way my dogs walk...nope they're not bi-pedal. But I notice that their pelvis does a side-to-side lift as the leg comes off the ground and swings through the air. I'll shaddup now. deedub
Thread: Transposer... | Forum: Carrara
Attached Link: poser camera operator in Carrara
Dumb newbie question...Do any of you folks know a good source of info on using bones in Carrara 3? I'm dealing with some of the same questions for one of my little projects: the human character has to interact with props made in Carrara, ultimately to be finished in Carrara for the superior lighting and textures. I'm on a Mac so I can't use phi-builder etc to set props up once they're imported into Poser. thanks, deedubThread: Carrara to Poser | Forum: Carrara
Attached Link: clapper board
I'm back asking for more details...if I can comprehend the answers. I have zero programming knowledge. I'm scamming for a decent used PC so I can use 'PhiBuilder', which worked on the old brokendown PC I got hold of. (It died.) So. I've built a simple object in Carrara, a movie slate or clapper board, to export to Poser. It only has 3 parts and the only movement is the stick on a hinge. Should I run it through Steve Cox's UV Mapper? "I found it more straightforward, when trying to build a heirachy from scratch, to use the Spawn Props routine to split out the groups, then Create New Figure, save that and do a quick edit to point back to the external obj file." Could you elaborate on the 'spawn props routine' for this Poser beginner? The link below is off topic (textures) but shows the clapper object.Thread: Carrara to Poser | Forum: Carrara
Thanks for the suggestion. I'll build some simple objects and experiment. I have TransPoser...it's good. I want to make poseable objects in Carrara for Poser, that is, go in the other direction. You're right, lights are awful in Poser. deedub
Thread: Transposer on the Mac | Forum: Carrara
Thread: Carrara saves the day | Forum: Carrara
Thread: Woodgrain tile | Forum: Carrara
I just want to say how very cool it is to have a Carrara users community out there to help solve the little problems I encounter! I tried the photoshop technique and spoke "BEAUTIFUL! JUST BEAUTIFUL" out loud. I'm modelling a 'virtual kitchen to demo different wood finishes on a cabinet builder's product. This tiling is essential, and I'm very thankful. I'll post the result when it's done. BTW, I find my modelling skill has taken a giant leap with Cararra Studio 3 as compared to the old RDS days. David
Falconperigot, Hoofdcommisaris: Thanks! I'll open a woodgrain in Photoshop and start experimenting. deedub, David
Thread: Painting a car in Photoshop | Forum: Carrara
