6 threads found!
dhulse | 10 | 142 | ||
dhulse | 6 | 322 | ||
dhulse | 1 | 72 | ||
dhulse | 7 | 181 | ||
dhulse | 3 | 101 | ||
dhulse | 18 | 578 |
16 comments found!
Has anyone tried the LoRez Monk figure? I'm trying to figure out how to make the robe conform to the legs when I change the leg positions or do a walk cycle.
Â
Thanks in advance!
Dan
Thread: Copying Runtimes from PC to Mac | Forum: Poser - OFFICIAL
You know, the only real reason I'm doing this is that if the runtime content doesn't have an installer, you need to manually copy over all the appropriate support files (objects, textures, etc.). With Windows, you can just drag and drop, and it will take care of merging.
On a Mac, it will replace the folders without doing the merge, so existing stuff gets deleted. Or am I doing things wrong??
Thanks for your help!
Dan
Â
I have about 7 gigs so far. I did try to move my runtimes to an external drive. These runtimes were installed on Windows. My Windows version of Poser sees them fine (in Bootcamp), but when I try to load them on my Mac version, it doesn't see them (shows "0" in the library window). The external drive is formatted as ExFAT.
This is on Poser Pro 2010.
Â
Dan
Perfect!! I like the external drive idea.
Thanks for your replies. Mac coming today!!
Dan
Thread: City Engine | Forum: Vue
Considering that this Vue-specific version only outputs .vob files, is there a way, once the city is in Vue, that you can export the city to another format (.obj)?
Dan
Â
Thread: Poser 8 is now available!!! | Forum: Poser - OFFICIAL
Thread: Trouble in (Content) Paradise | Forum: Poser - OFFICIAL
IÂ tried the re-registration, but CP detected the email address as a duplicate and wouldn't let me proceed.
Sheez, can they make this any harder?
IÂ don't think its spam filtering (though IÂ checked, just in case). IÂ did initially have a couple of emails from CPÂ support, when they started asking for serial numbers. But after a couple of emails the responses stopped.
Dan
Â
Thread: Vue 6 is available for download! | Forum: Vue
Is the downloader for the main V6I application allow for "resuming"? I couple of times now it has stopped because of a server disconnect. I'm wondering if it will pick up where it left off, or if there's a danger the file can get corrupted (not another day to download...!!!).
Thanks.
Thread: Mac Poser to Mac MotionBuilder to Mac Maya and back | Forum: Poser - OFFICIAL
Thread: Poser 6 & BodyStudio 2.5 | Forum: Poser - OFFICIAL
I have BodyStudio for Cinema 4D, and Reiss posted a beta version of the plugin for Poser 6. I have not tried it yet, but at least it sounds as if they are working on it.
Thread: Problems with Ents | Forum: Poser - OFFICIAL
From the zip file I received, the .obj file is in the "Geometriescurios creatures" path. The cr2, png, and rsr files are in the "LibrariescharacterCurio's Creatures" path. I tried wiping out these two folders and grabbing the files from the zip, but the same thing happened. Nothing seems to be modified during Poser use. I emailed Curio but got no response yet. Dan
bloodsong, No, I did not use the grouping tool. I will try the read-only trick and let you know. Dan
Thread: Carrara 3 Beta | Forum: Carrara
Anyone with the Beta know if trees limbs/leaves can be animated to simulate wind motion?
Thanks.
Dan H.
Thread: Pro Pack Animation Sets | Forum: Poser - OFFICIAL
Hey,
Thanks for the tip. I figured out how to do it. Here's a quick outline of the steps in case anyone else interested:
Dan
Thread: new Predatron Lorenzo Lorez | Forum: Poser - OFFICIAL
