11 threads found!
doctorkoan | 1 | 70 | ||
doctorkoan | 3 | 108 | ||
doctorkoan | 0 | 44 |
(none)
doctorkoan | 3 | 132 | ||
doctorkoan | 3 | 129 | ||
doctorkoan | 11 | 261 | ||
doctorkoan | 4 | 125 | ||
doctorkoan | 3 | 84 |
2003 Feb 16 9:28 AM
doctorkoan | 2 | 26 | ||
doctorkoan | 0 | 3 |
(none)
doctorkoan | 1 | 13 |
14 comments found!
Thread: HaiGan's Goatee Prop for Mike | Forum: Poser - OFFICIAL
That would be very cool. I'm not much handy with any of the higher level stuff in poser. Mostly due to lack of a good modelling package that can create morph targets.
Thread: Mike 2's big hairy brows | Forum: Poser - OFFICIAL
Thread: Help Creating Phonemes for use in mimic2 | Forum: Poser - OFFICIAL
Thread: Strong Anime Male figure, morphs? | Forum: Poser - OFFICIAL
I found it by doing a google search for "Simon for Sara" Thanks for all your help everyone!!
Thread: Exporting the Wireframe view as Paths for Illustrator or Photoshop | Forum: Poser - OFFICIAL
Attached Link: http://www.adobe.com/products/streamline/main.html
oops, I cut and pasted the wrong link.Thread: Exporting the Wireframe view as Paths for Illustrator or Photoshop | Forum: Poser - OFFICIAL
Attached Link: http://www.marsdust.com
Adobe Streamline is a program designed for converting bitmaps into vector art for illustrator. It can be kinda touchy on complex bitmaps, but you should do just fine with wireframe or outline exports from poser. I believe Streamline is pretty inexpensive too.Thread: Four-armed Anime Doll (repost) | Forum: Poser - OFFICIAL
Thanks to both of you. You are right. The bloodsong tutorial is kinda in-depth. I also don't have the software needed to slice a poser figure like that. Do you think that the chest is the best place to parent the figure or would the hip be better?
Thread: Need Flash Animation tutorials | Forum: Animation
Attached Link: http://flashkit.com
try Flashkit.com, I know they have an .swf based tutorial that goes over all the basics. They also have a number of open source .fla files with animation that you can study that range from simple to elaborate.Thread: How do I make generated 'visuals' (iTunes, WinAmp styled visuals) | Forum: Animation
Thread: salary? | Forum: Animation
Does anyone want to be daring and tell how much the average hourly rate they charge clients is?
Thread: Choppy animation | Forum: Animation
I encountered this problem last week. I run a Mac system. It turned out that an extention to my video card was accidentally disabled. Even if you run on another platform, check to make certain that all your video card software is in place.
Thread: how do i get poser animations into bryce? | Forum: Animation
Another work around, depending on your situation, might be to render your bryce animation first, then import it into poser before setting up the poser animation. I know this works on the Mac. If you judiciously stroyboard ahead of time it would make this technique easier. The advantage to this is that you can set up keyframes right over the Bryce movie, making synching a little easier. Now if you Have to have the character(s) walk behind a brycy object, you will need to import that object into Poser, which might be problematic depending on the situation. In that case you could do a seperate Bryce animation with the solo renderer and use Premier to composite it after the initial Bryce movie in Poser rendering.
Thread: Bryce 3D animation problems | Forum: Animation
The above is good advice. As far as the clouds moving, there is a "static cloudplane" (or something like that in the skylab (at least in my Mac version). Try that. Make certain you set it before you set any keyframes or you might find yourself having to untangle a small mess.
Thread: Free DJ Turntable model? | Forum: Poser - OFFICIAL
