16 threads found!
douglas | 2 | 12 | ||
douglas | 5 | 30 | ||
douglas | 4 | 35 | ||
douglas | 2 | 29 |
2000 Nov 03 6:00 PM
douglas | 4 | 20 | ||
douglas | 5 | 34 | ||
douglas | 2 | 14 | ||
douglas | 2 | 20 | ||
douglas | 1 | 16 | ||
douglas | 6 | 35 |
2000 Jan 18 11:53 AM
douglas | 8 | 37 | ||
douglas | 3 | 43 | ||
douglas | 5 | 40 | ||
douglas | 8 | 57 | ||
douglas | 4 | 28 |
24 comments found!
Thread: bryce 5 | Forum: Bryce
Thread: So Adobe buys Carrara!! | Forum: Carrara
Ok now I understand, I did check the web site unfortunately is in german and the part I got right where it said demo did not work as I spected because there was no demo, well maybe in other time I will have chance to see how it looks.
Thread: My latest Work | Forum: Carrara
Thanks tom all for the comments and help support, but I still haven't found what Im looking for, "I've heard this song before" well here is the thing, I get use to the Bryce system where you have just one camera, so the saving the views was very useful, In carrara you can save views on a similar way by giving a name to them, but those views and name disappear next time I open the file. Due to the work I do, I need to render a minimum of 8 pictures each time, that's why for me the best way to do it is with one camera, and animating the camera one frame at the time, so that I can save a bmp or jpg sequence. This system at least this far can not be possible if I have many cameras. Im wondering if this problem is some kind of bug in the program, because why in hell they will put a tool that is useless after you close your file, I have to start over to get the saved views I want. About the sky, I believe that this four seasons works almost like Bryce sky lab, with the difference that you cant save the sky you do, so if any one knows how to save them, please let me know, to save a sky picture from Bryce could be a good way to do it, to but is no exactly what I have on mind Thanks again Doug.
Some one said something about a sofware called monozoom. Could any body tell me more about it? I have never heard such name before, except for the leica monozoom lens.
Thread: Bye Bye Bryce | Forum: Carrara
Thanks Mark, i have tried that before, but with not good results. the geometry dont show up after converting, it just let draw new polilines but I cant see the object I want to modify. I dont know what to do. Doug
Thread: Good mirror shader? | Forum: Carrara
Hello there, I just finished one of my works where I have to use a mirror, the best way I find to get a realistic mirror was to set, for the same mirror shader that comes with the program, set the color tab to color and chose black, that will do it, or at least it works for me Good luck. Douglas.
Thread: Ok, fixed the trees.. | Forum: Bryce
Thread: Hello people Im back | Forum: Bryce
All comments are more than welcome, one of the reasons I have no put to much efort for the bacgrouns is that my file sise excede 80 megs, due to the trees in the front, is true I Will need to do something about, but Im planig to do a litle photo montage with some aereal Photographs. Will see what happens. Doug.
Thread: Bluesman | Forum: Bryce
pretty cool I like that brick wall, It looks almost real How about some crazy texture for the alien too. This far is a bit too gray dont you think. The ilumination is very good, Is nice how you play with the colors. Doug.
Thread: vrml problems | Forum: Bryce
Sorry I have no been able to answer in a while, well the hing is that, something wrong is happening with bryce because, I can open the files without problems in 3d studio viz, ergo the files are fine, but I am now using *.obj format, that gives me the same result and some how I do not need the vrml sistem anymore. But thanks anyway for your offer to help. Doug.
Thread: Another of My final works | Forum: Carrara
Im glad you like it Ok lets say that it can take from 4 to 8 hours, depending on how close I get to the main building. Im using a 450 pIII with 250 ram. The model was created half with autocad and the other half with archicad. vehicles and some trees, i got them from the free stuff in the 3d cafe.com. and I use to keep them in my objects library for future uses. kind of recicling sistem. Normaly I have to render from 6 to 12 diferent views of the same model, on that case I set an animation where there will be just the amount of frames I need, and then I save as a bmp sequence. thats more or less how I do. Doug
Thread: Can carrara handle this kind of models | Forum: Carrara
I wish I could help you with that, but there is a few small problems, the main one is that they belong to my company, and the second is that they use to be rather large, normaly my models excede the 30 megs, even If was able to give them away, I coul not send them throug the internet. sorry.
Thread: Carrara image, and a question | Forum: Carrara
Impresive work I have to try this program, right now I just now it by name. very good looking reflections.
Thread: All the underwater challenge images... | Forum: Bryce
